It is currently Mon May 20, 2013 2:17 am
What the Hell Is this
• Page 1 of 2 • 1, 2
Contiued weird shit with these spreakers I bought. I have a spare woofer so there is no great big disaster, I thought I'd seen it all with the binding posts . The woofers all seemed in great shape surrounds in tact no creases in the honeycomb and suddenly I looked down at the back of the bottom woofer on one speaker and saw this. What you're looking at is a hunk of pink insulation with caulking holdig it there. What The F--K!!!!
Re: What the Hell Is this
Wow, backyard mechanics! This made think of my brother. He bought a old 59 GMC truck, this was years ago! and drove it about a week and started hearing BAD gear grinding and clucking from the transmission. When he pulled it out for repair what did he find? They put saw-dust! in the transmission to lesson the noise! The things people do to fix a noise!!
amassing!
amassing!
When I was a kid alot of my neighbors would put there shit speakers out for the trash men, most of the time it was because thay ripped the woofer. Hell I had no money " I was 10 or 11 at the time" so I would just use white glue on the back of the woofer and good as new.
Not saying It was wrong for the last owner to do what he did, but kinda crappy not telling you about his little patch job.
Art.....this just strengthens my argument that a person should have to show I.D. when buying caulking guns.
Being in construction for 30 yrs I've seen some of the wildest things done with caulk and duct tape........
One thing, after its all said and done YOU will have the satisfaction of knowing it was YOU that brought them
back from caulking hell and restored them to "Original"
Good luck Art.....keep us posted.
Perry
Perry
I'm pretty sure that's not a Carver approved repair.
I can't believe you didn't hear that. On the plus side the repair will be a snap.
Never had them turned on. Binding posts were in such terrible shape I couldn't risk ruining my amps.
TOLD YOU TO TAKE THE REAR GRILLS OFF
most likely...........
the cone shifted on the spider.....and caused the voice coil to rub and make unwanted noise (sometimes a lot)
..... mechanically "off loading the cone" from the rear will stop this noise........
....THIS IS NO FIX AT ALL...the peformance, and peramiters of the driver is eliminated.
...solution:
- recone the driver
- replace it
...good day!
...solution:
- recone the driver
- replace it
...good day!
country's...pure sole...
Fixed by an:
I think you should probably add "bought by an". Comon I know you were probably thinking it.
tah , I agree with some of the other members.....This will be a great project for you , and when all said and done , you turn them on , and you say to your self " I did that , I brought them back to life...!!!! "...I think it was meant to be.....
"Wow, backyard mechanics! This made think of my brother. He bought a old 59 GMC truck, this was years ago! and drove it about a week and started hearing BAD gear grinding and clucking from the transmission. When he pulled it out for repair what did he find? They put saw-dust! in the transmission to lesson the noise! The things people do to fix a noise!! "
Backyard mechanic? Not. Try common shyster. Putting sawdust in a noisy transmission is an old trick of crooked used car/truck sellers! He was not trying to "fix it"; just mask the noise until he could unload it...
That's some weird shit Art. Thank God you bought them and saved them.
I believe that it was "meant to be".
I believe that it was "meant to be".Re: What the Hell Is this
Need some replacements ?
