It is currently Sat May 18, 2013 6:13 am
Weird resistance measurement
fstik
Post Tue Jun 02, 2009 12:03 pm
Hello fellow Carverites...
Just finished upgrading my Original ALS' to Plats with rebuilt ribbons, replacement woofers from Dynavox (before the price increase!) and a pair of Plat crossovers. Since I didn't have the Biamp terminal cups, I just attached the woofer and ribbon wires from the crossover input together and soldered them to the respective input terminals. My issue is this - when I attach a multimeter across the input terminals to the speakers, I am only reading about 4 ohms. This don't seem right ](*,)
Can anyone with a set of plats check the input resistance please?
Thanks,
fstik
Post Tue Jun 02, 2009 12:32 pm
Re: Wierd resistance measurement
The Plats & the Originals w/ Plat conversion don't have the exact same impedance, if I remember correctly. I think weitrhino has a pair of converted Plats; perhaps he can measure for you...
fstik
Post Tue Jun 02, 2009 12:59 pm
Thanks for the quick reply Rabbit... This isn't really a Plat upgrade... I am using an original plat crossover, as well as the original (well, replacement) Plat woofers. Should be the same as a stock pair of Plats. Would still be interested in resistance measurements of the Carver Upgrade Plats as well as the stock Plats.
fstik
Post Tue Jun 02, 2009 1:11 pm
The DCR across your binding posts is not the speaker's true impedance.
fstik
Post Tue Jun 02, 2009 2:09 pm
F1nut wrote:The DCR across your binding posts is not the speaker's true impedance.
That is true, I would need an LCR bridge to effectively measure that. However, I'm just looking to get a comparison reading from an already functional set of plats.
fstik
Post Tue Jun 02, 2009 9:02 pm
Re: Weird resistance measurement
Gotcha.
