It is currently Sat May 25, 2013 2:47 am
Hook up wire
• Page 2 of 2 • 1, 2
I think when you take the back off and look at the workmanship there things were designed to be cost effective. The crossover built on a little chunk of what we used to call beaverboard. Cheap little binding posts 3.49 each. Woofers that used to sell for about $25 bucks a piece. The ribbons are a chunk of gold or silver paper with a couple of strips of aluminum foil stuck to them with some litte magnets glued to metal on either side of them. Now don't get me wrong to take all this inexpensive stuff and come up with something that good is a real stoke of genius. This guy is truly a master at what he does. He's enabled us to own something that is rivaled only by speakers in the 8 to 10 grand range for around 2500 when they were new.I would love to have something like Martin Logan Summit speakers as my last hurrah. But at over 10 grand a pop i'm willing to bet there isn't that much difference(certainly not money wise) in those and my good old Carvers.I just can't get my head around the idea that you can get enough power to those woofers with those little skinny wires. It's kind of like trying to run your 15amp skil saw using one of those little thin extension cords. Let's face it Carver is in the business of selling product. He's not going to get up there and say I made this speaker with a lot of cheap components. I'm willing to bet that if he made those things with top of the line stuff they would have been around 10 grand and there would not have been that many produced. I certainly wouldn't have owned one. He made the Silver 7 tube amps at 24 grand a piece. Not many of those around. he made the silver 9t's at around 2 grand and everybody could own one. I'm willing to bet there isn't 20 grand difference in the sound. I really belive the speakers allow us the opportunity to improve. I'm willing to bet that if someone could build a high quality crossover that that would even further improve them. Anyway I'm a complete dummy when it come to all these stats and electronic jargon but I do know what sounds good. Those changes I made in my Original speakers made them sound better especially the bass. Art
Re: Hook up wire
Art, talk to Jesse about the mods he made to his Amazings....
Re: Hook up wire
Art, try to come to the Fest this year. You will have a great time & when you meet Bob you will understand. He has no pretension about him, very down to earth.
Of course the ALS were built with cost in mind but not at the expense of sound. A super-duper board to mount the crossovers on would cost more but not change the sound a bit.
The "cheap" woofers for another example. They were so bad that the manufacturuer didn't want to make them for Bob. It turns out that the design of them was necessary to work properly in the open baffle (something about "Q") and heavy duty woofers with big magnets would NOT have worked in that design.
I was going to re-wire my Silvers until the Fest, after that I came home & "listened" to them. The bass is excellent. I've decided to leave them alone.
BTW (sorry Dreamer) there was a set of Martin Logans there and they couldn't touch the ALS. Not even close.
Just my .02
Just my .02
Re: Hook up wire
radioeng2 wrote:Of course the Cardas is a litz wire design. Whereas the Monster is just shit wire. .
ShitWire is my cable company. All of my cables come from there and I can't hear the difference. Bwaaahahahaha kidding Marc.
Re: Hook up wire
Remember what Mr. Carver told us at Carverfest....... He said you can most certainly change or swap any and all of your hook up wire with the wire of your choice and the "high buck" wire or "$hit" wire you choose will definitely change the sound presented to you. Hopefully it will sound the way you want it to, and if it does that's great I'm happy. The bottom line is whatever your results may be are not what I originally intended, but if you like it that's great!" That may not be exact word for word, but it's pretty darn close. Mr. Carver expressed the same feelings regarding speaker cable. He said that the "big daddy" cable will definitely have the least effect on the signal while on it's way to the speakers, but many types of speakers were not originally intended to be hooked to almost zero loss cables and in some cases may not sound so good. Then there is the other side of the coin..... and that was as far as that went.....
Rainman
Rainman
Re: Hook up wire
That is a very fair and accurate acessment of what he said at last years CF.
Re: Hook up wire
I sure would like to view the Q&A video from CFest 08 !!
Re: Hook up wire
So getting back to my original question about a good type of wire to use in a refit my impression would be that very few people have done it or those who have didn't find that it did much good anyway. Guess I'll stick with the Cardas then.P.S. I wonder what Bob's answer would have been if you had asked him about the binding posts. Do you think he tested 10 different models and come up with those ones??????????Art
Re: Hook up wire
I never got around to changing the binding posts on mine,,,but why do'nt you pm jesse---F-1,,, I'm sure that he can point you in the right direction.
Re: Hook up wire
Back to the topic at hand....a couple of Polk people used silver wire inside (don't recall what gauge), and reported great results for not too large of a cash outlay. What seemed odd to me was that they retained the blade connectors instead of soldering directly to the various terminals, I'd think that you'd want to eliminate all those potential corrosion spots. Then again... WTF do I know !!
Re: Hook up wire
Those binding posts are crap. I had to change mine before I could even listen to them because they would not accept the banana plugs or spades on my MIT speaker cables. I went with Cardas posts, problem solved.
IIRC, the stock chassis wire was soldered to the terminals. When I upgraded to Cardas chassis wire, I soldered all the connections. However, if one where to use spade connectors, a treatment with DeOxit and ProGold will prevent any issues down the road.
It made a huge improvement to my ears.
