It is currently Tue May 21, 2013 4:59 am
carver al-3plus
Post Sun Jun 14, 2009 12:06 pm
Re: carver al-3plus
Don't ask permission. Apologize later.
Post Sun Jun 14, 2009 1:13 pm
Re: carver al-3plus
I stole my mint black AL-IIIs a couple months ago for $250....
It was a 500 mile drive, but I got a ride from a friend that was making the trip for his company anyway.
stevewithrow
Post Sun Jun 14, 2009 3:10 pm
Re: carver al-3plus
BillD wrote:I agree with Steve. They'll certainly top any $1,000 speaker available today (if they're in good condition, speaker-wise). ALSs, in general, will probably top most $10,000 speakers.
Do you mean the AL-III,s ...or the ALS,s...I was referring to the AL-III,s.....My better half said she liked the sound of the AL-III,s better then the ALS,s......Then she admitted that the AL-III,s looked better , that the ALS,s looked like car doors.... :shock: .....I have had MB quart,s ...Paradigm studio ref,s....Listened to M & k...Martin Logan's.....Ect....Haven't had the chance to hear the Polk SDA,s....Which I want to real bad..( the older ones )...But for me , the AL-III,s...even if I had to spend 1000.00 , sounded much better....So if you have a chance to pick up a GOOD pair, I would go for it......You can always sell them.....But I dont think you will...When I got the ALS,s for 1000.00.....Im still surprised they still go for that amount....Im still in awe of the sound....I may be a bit biased .
mewisemagic
Post Fri Jun 19, 2009 10:13 pm
Re: carver al-3plus
is there a way too see the woofer to check the surrounds for wear/age or damage ?
carver ct29v,tfm-15cb,tfm-35x,m1-ot,tlm-3600, pair of 9 t's ,c5,adcom 535 II,oppo 981 dvd, polk sda srs 2.3tl,polk sda srs 1.2
tfm-42,AL-III+, yaqin 10l
Post Fri Jun 19, 2009 10:23 pm
Re: carver al-3plus
mewisemagic wrote:is there a way too see the woofer to check the surrounds for wear/age or damage ?
Wabbit?? Wabbit?? What says you Gary?
Post Sat Jun 20, 2009 8:32 am
Re: carver al-3plus
You'd need to CAREFULLY lie them down (their heavy) on their side (or face if you put them on a couple of pillows or a couch/bed/ etc.) & remove the bottom panel with a LARGE phillips screwdriver (4 screws. You can use a drill-driver, but I'd be VERY careful & make sure you use a huge phillips bit.
Make sure when you put them back that you get the back 2 spacers in the recessed they set down into (tilts the speaker back slightly)
mewisemagic
Post Mon Jun 22, 2009 11:43 am
Re: carver al-3plus
got the al3's and amp. they sound very good to me even though the room i put them in is way to small O:)
weitrhino
Post Mon Jun 22, 2009 1:12 pm
Re: carver al-3plus
Seems to me in the the last year's time you have gone compleeeetely OCCD.
mewisemagic
Post Mon Jun 22, 2009 2:03 pm
Re: carver al-3plus
yes, i've gotton alot of carver stuff,but last nite wife said NO MORE :(
Post Mon Jun 22, 2009 2:14 pm
Re: carver al-3plus
My problem is that I have no one to tell me no more Carver equipment. I just keep buying and buying. I know I have OCCD bad! ](*,)
