Carver AL 3 refinishing
And yes, everything works well!
Dave
It is currently Sat May 18, 2013 6:36 pm
F1nut wrote:No, you're not understanding correctly. If the black color is a stain that was applied directly to the wood, stripping will most likely not remove all of the black color. You will have to bleach the wood after stripping and cleaning to get all the black out. Contary to the article recommending two part bleach for removing color (stain), Clorox is actually the better choice. Do it outdoors in bright sunlight, which will help the Clorox do it's job. Let the wood dry for a few days after and sand smooth before staining/finishing.
One other thing, taping off and stripper are not two things that work together. You should remove anything attached to the wood before stripping.
