carver Al-3 Plus, 4 Ohms or 8 ohams
topvideo
Post by topvideo » Wed Jun 24, 2009 12:08 am
Hi evervone, my name is Alan and I am new to this forum.
I am the owner of a Al-3 plus since 1998 and 3 months age I change my power amp to a Rogue m-120 monoblocks ( http://www.rogueaudio.com/Products_m120.htm ) which has separate 4 and 8 ohm speaker taps in the back, and for whatever reason ( I must be daydreaming) I connect the al-3 to the 8 ohm speaker taps 3 months ago and use it 2 to 3 hours per day. My Question is (a) Is the al-3 is Impedance at 4 Ohms? and (b) Will it cause damage to the amplifier or the speaker if I use the incorrect ohms taps?
Today, I moved the speaker cable back to the 4 ohm taps, and I hope I didn't damage anything.
The following is my system info:
Shanling CD-T100C CD Player
Audio Experience SYMPHONIES Tube preamp
Rogue M-120 Tube monoblocks
Carver AL-III Plus Speaker
MIT Shotgun S2 Interconnect (CD to preamp)
Audio metallurgy GA-0 Interconnect (preamp to amp)
Transparent Ultra bi-wired Speaker cable
ps audio Power cord
Thank
Alan
Re: carver Al-3 Plus, 4 Ohms or 8 ohams
Post by TNRabbit » Wed Jun 24, 2009 2:26 am
Welcome, Alan~
Yes, the AL-III impedance is 4 ohms. However, I'm not sure what connecting to your 8 ohm taps would do to your amplifier. I'm sure someone with more knowledge about amplifier topology will be along to answer your question soon!
topvideo
Post by topvideo » Wed Jun 24, 2009 2:56 am
Thank You TNRabbit. As of today, everything still working and sound good, it was a stupid mistake and I just don't want to damage the amp or the ribbons.
Alan
Attached is a photo of the set-up
Post by TNRabbit » Wed Jun 24, 2009 5:42 am
Beautiful! =D> =D>
If you didn't push the amps hard while they were hooked to the incorrect outputs, I doubt you did any harm...
Post by thuffman03 » Wed Jun 24, 2009 9:23 am
Welcome to the forum. Wonderful looking system you have.
weitrhino
Post by weitrhino » Wed Jun 24, 2009 2:16 pm
My sense is the amps worked a little harder to drive the load, but like rabbit says if you didn't push them hard then there's probably no reason to worry.
skip
aka (Sasquach)
Post by skip » Wed Jun 24, 2009 3:19 pm
Beautiful system! How do you like the Shandling CD player? If the amps still work, I doubt any harm was done. Did they overheat at all?
Sasquatch
topvideo
Post by topvideo » Thu Jun 25, 2009 2:26 am
Thank everyone for the help, both amps and speakers are working fine, today I use piano music to test the speaker for 2 hours and they sound as good as the first day I bought it. Also received email from tech support of Rogue Audio, they stated the amps is able to handle such abuse and I will only get slightly lower power if use the incorrect taps.
As for the Shanling, I own it for 3 1/2 years, it build like a tank, nice up-sampling to tightening up the resolution & soundstage and I was very happy with the rich & colorful midrange performance. However the there is no tech support from the company (they never return email) and the player is very sensitive to feedback and will skip if the cd is scratch.
Thanks
Alan
Return to “Carver Speakers”
