It is currently Sat May 18, 2013 5:11 am
tfm35 with als111
Re: tfm35 with als111
tfm-42,AL-III+, yaqin 10l
mewisemagic wrote:might be better to use 2- 24's
I agree. Bi amp.
Just a thought.
elgrau wrote:Try both; whichever sounds better go with that. Also, if alsIII's much less than 8 ohms impediance then bridging the two 24's probably not the way to go. Or were you bi-amping them?
One 24 would go to the ribbons and the other 24 to the woofers......
I'm assuming the ribbons need more power than the woofers from everything I've read (my instinct would be the opposite with the bass drawing more power).
FrankieD
Thanks
elgrau wrote:One day I'll post a plot of dissapated power vs frequency (at constant SPL). I suspect it will show ~90% of power goes to frequencies below ~1k Hz.
