engtaz wrote:Chauss wrote:engtaz wrote:Those silvers probably won't get off the new ALS's.
Yeah, but there are supposed to be 2 pairs there....I do not think 115db speakers need to be bi-amped with close to 1KW of power!
Even one pair would be overkill for that!
No such thing as over kill with amps.
I was curious as to the specs so I looked them up.
Wilson Audio Specialties Sophia loudspeaker Specifications
Sidebar 1: Specifications
Description: Three-way, floorstanding, reflex-loaded loudspeaker. Drive-units: 1" (25mm) inverted titanium-dome tweeter, 7" (178mm) paper-cone midrange unit, 10" (254mm) aluminum-cone woofer. Frequency response: 29Hz-22.5kHz, +0/-3dB. Sensitivity: 89dB/2.83V/m. Impedance: 4 ohms nominal, 3 ohms minimum.
Recommended power: >12Wpc.Dimensions: 41" (1042mm) H by 12" (305mm) W by 18" (457mm) D. Weight: 160 lbs (72.7kg) each.
Finishes: High-gloss automotive paint.
Serial numbers of units reviewed: 0073 & 0074.
Price: $11,700/pair. Approximate number of dealers: 41.
Manufacturer: Wilson Audio Specialties Inc., 2233 Mountain Vista Lane, Provo, UT 84606. Tel: (801) 377-2233. Fax: (801) 377-2282. Web:
www.wilsonaudio.com.
