It is currently Sun May 26, 2013 4:33 am
Amp Casulity
Post Sun Sep 25, 2011 11:32 am
Amp Casulity
Well, I suppose I'm the first casulity--plugged the amp in yesterday,,played fine,,again last night,,,this morning,,nothing,,no tube glow--checked fuse,changed power tubes,,changed power cord-changed outlets,, I'm gonna check the input tubes,,but somehow I suspect it's the power supply.Any thoughts before I go poking around with a VM.And yes,,this was blessed by Bob at the fest.Any help appreciated.
Post Sun Sep 25, 2011 11:38 am
Re: Amp Casulity
if amp got moved maybe components are touching or ping pushed in tube socket shorting something.
Post Sun Sep 25, 2011 11:40 am
Re: Amp Casulity
With no tube glow, start in the Power Supply ahead of the heater circuit.
Post Sun Sep 25, 2011 11:41 am
Re: Amp Casulity
Roy,, I'll take a peek,,tubes test well,,I did not move the amp--guess I'll start troublshooting.
Post Sun Sep 25, 2011 11:50 am
Re: Amp Casulity
Sorry to hear George,,,good luck.
Post Sun Sep 25, 2011 11:53 am
Re: Amp Casulity
found it-- IEC fuse-- can anyone look at theirs and tell me the value,--looks like a 250 ??AMP
Post Sun Sep 25, 2011 12:05 pm
Re: Amp Casulity
I wonder why it blew so soon ? I'd still take a good look around and make sure nothing is shorting out !
Post Sun Sep 25, 2011 12:09 pm
Re: Amp Casulity
Seems like Roy had that problem also at the fest. He thought it may be because he did not have an on/off switch installed yet.
Anyway, glad you found the problem George.
Post Sun Sep 25, 2011 12:12 pm
Re: Amp Casulity
Don,, an on/off switch is being installed as we speak-- I was lazy and just used the power (IEC) connection.I've checked all of the solder joints and wiring,and I feel sure that it was me removing/replacing the cord for on/off.Can they make the writing any smaller on the fuse. ](*,)
AlexSauter
Site Admin
Post Sun Sep 25, 2011 12:22 pm
Re: Amp Casulity
Zoot Horn wrote:Don,, an on/off switch is being installed as we speak-- I was lazy and just used the power (IEC) connection.I've checked all of the solder joints and wiring,and I feel sure that it was me removing/replacing the cord for on/off.Can they make the writing any smaller on the fuse. ](*,)
Roy did have this same problem on his amp, he thought it was due to the AC current arcing across the terminals as you pulled the cord out or pushed it in.
RIP BillD
(Stereo System)
Carver Pro PT-1800
Sunfire Prototype TGA-2375
Carver TX-2 Tuner (not used)
Post Sun Sep 25, 2011 12:27 pm
Re: Amp Casulity
Fuse rating please sir? Looks like it says F2 Al 250volt--I'm assuming it's a 2 am 250 volt fast or slow?
AlexSauter
Site Admin
Post Sun Sep 25, 2011 12:29 pm
Re: Amp Casulity
The fuse is 2A 250V fast blow
RIP BillD
(Stereo System)
Carver Pro PT-1800
Re: Amp Casulity
Thank you sir !!!
Post Sun Sep 25, 2011 1:16 pm
Re: Amp Casulity
Sorry I did not mention it before. Get spare fuses till switch is installed.
Post Sat Oct 01, 2011 11:12 am
Re: Amp Casulity
fuses,tubes,,all swapped-- certifiably DEAD now--
Return to CARVERFEST 2011
