It is currently Tue Jun 18, 2013 6:04 pm
Amp Casulity
Post Sat Oct 01, 2011 1:49 pm
Re: Amp Casulity
That sucks ! Now what ?
Post Sat Oct 01, 2011 2:16 pm
Re: Amp Casulity
I suppose I'll send it to someone who has better skills than I do.Not to be short,,just kinda frustrated with it. ](*,)
jerryj12
Post Sat Oct 01, 2011 3:42 pm
Re: Amp Casulity
George, gimme a call sometime maybe we can put it on the bench here.
Post Sat Oct 01, 2011 3:56 pm
Re: Amp Casulity
do you have a multi meter?
does it get B+ 450v (big cap)
on the output tubes:
pin 9 355v
pin 7 415v
pin 3 14.53v (bias)
pin 2 V2= .002v pin 2 V3= .01v not sure why this voltage is not the same, maybe a typo???
input tubes:
pin 1,7 76v
pin 6 275v
pin 3 .359v
all these voltages are right at the tube socket pins
put heat shrink on your prob tips so that only the very end shows, you will thank your self latter on.... :-"
Post Sat Oct 01, 2011 4:36 pm
Re: Amp Casulity
Thanks Mike,, allright,,I'm going in,,,gotcha on the heat shrink
Post Sat Oct 01, 2011 4:38 pm
Re: Amp Casulity
Zoot Horn wrote:Thanks Mike,, allright,,I'm going in,,,gotcha on the heat shrink
:lol: :lol: :lol: :lol: :lol:
Get're Done Boys ! [-o< [-o< [-o<
Post Sat Oct 01, 2011 6:07 pm
Re: Amp Casulity
To add my readings....
While set to 120vac input....
Outputs...
Pin #9 - 384vdc
Pin #7 - 437vdc
Pin #3 - 13.6vdc
Inputs....
Pin #1 &7 - 87vdc
Pin #6 - 294vdc
Pin #3 - .39vdc
All readings with no audio drive, inputs not shorted, outputs loaded by 8 ohms.
One additional is the voltage across the screen dropping resistor (the big blue one) is 56vdc. This amount of drop indicated the total screen draw for all 4 output tubes.
My filament voltage at the transformer output (at the terminal strip) is 6.4vac.
Post Sat Oct 01, 2011 8:07 pm
Re: Amp Casulity
We're pulling for ya Zoot. I hope you can get it sorted out.
Return to CARVERFEST 2011
