CarverFest Location, and Directions
Rules, Directions, Location, Cabin Information
Locked
Post by Toy Maker » Thu May 05, 2011 3:06 pm
Here is a direct link that will make CarverFest the DESTINATION, all you have to do is fill in your Departure address
Google CarverFest Directions
This link is a compiled Google Earth mapping of the CarverFest cabin locations.
http://www.carveraudio.com/CarverFest/CarverFest.kmz
If you already have Google Earth, just download the file, unzip it, and the map should import directly into Google Earth for you.
If you do not have Google Earth, here is the link to the free download.
http://earth.google.com/
ENJOY!
Here is travel information from the somewhat local airports
Asheville, NC (AVL) LINK
Charlotte, NC (CLT)LINK
Atlanta, GA (ATL)LINK
Knoxville, TN (TYS)LINK
The closest airport is Asheville, NC (airport code AVL) LINK, which is about 70 miles from Bryson City.
Asheville is a very small and easy airport to travel through, and is serviced by the following airlines: USAir, Delta, United, Northwest. However, because Asheville is not a major hub for any airline, it may be difficult to find a direct flight from your departure city.
If you fly USAir or Delta, you will likely connect in Charlotte, NC (CLT)LINK or Atlanta, GA (ATL)LINK, respectively. By the time you layover in one of these cities, fly to Asheville, and then drive the final 70 miles, it might be quicker to just end your air travel in either Charlotte or Atlanta and drive the rest of the way (about 3 hours from either airport). Rental car variety and bargains may be greater in these major cities as well.
A secondary city to consider is Knoxville, TN (TYS)LINK, but don't be fooled by the apparent close proximity. Knoxville is through the Smokies and the drive is slow, difficult and unpredictable depending on time of day and season.
Re: CarverFest Location, and Directions
Post by Toy Maker » Thu May 05, 2011 11:25 pm
According to Tim, the new driveway off 74 has been PAVED all the way to the top of the hill...
YEAHAAAA TIM !!!!
Locked
Return to “CARVERFEST REFERENCE INFORMATION”
