Bob Carver's "CarverFest" 20w Tube Amplifier
HOW MANY AMPS WILL YOU NEED
Poll ended at Thu Jun 23, 2011 10:20 am
1
6
25%
2
12
50%
3
2
8%
4
4
17%
5 OR MORE - CONTACT ME VIA PM.
0
No votes
Total votes: 24
Re: Bob Carver's "CarverFest" 20w Tube Amplifier
Post by hewlew1 » Thu Aug 18, 2011 8:49 pm
Just as a point of clarification there are 2 conflicting post listed on the forum one states that the tubes are 12AX7's the other states that the tubes are 6AX7's. I would assume that since the output tubes are 6BQ5's that the heater filiment voltage from the transformer is 6 volts. Which would make the correct tubes 6AX7's. Is this correct?
Post by Toy Maker » Thu Aug 18, 2011 8:49 pm
$200 PER AMP KIT
but it might be less. :lol:
base not included in $200 or less price
Post by DaveS » Fri Aug 19, 2011 2:51 am
I don't care what they cost just tell me what I owe!!!! I'll pay in cash at CF and couldn't care less. A once in a lifetime opportunity to have as my "Build your own amp 101" class teacher Bob Carver PRICELESS!!!!!!
My ONLY concern after seeing the pictures of the wireing, HOW THE HE'LL AM I GOING TO GET THESE HAMHOCKS OF FINGERS OF MINE IN THERE TO DO THAT!!!!!!!!!!!!,!??.?.?.?.?.?.?.?
Post by DaveS » Fri Aug 19, 2011 2:54 am
I'M WORRIED.
Post by OconeeOrange » Fri Aug 19, 2011 9:25 am
+1
Post by TNRabbit » Fri Aug 19, 2011 12:04 pm
That's what the needlenose pliers are for.
I also suggest you see your dentist & doctor & scarf up any tools they've deemed old/replaceable. Hemostats are PARTICULARLY useful.
Post by OconeeOrange » Fri Aug 19, 2011 5:34 pm
TNRabbit wrote:Hemostats are PARTICULARLY useful.
I have no idea what that is.
I think what will be PARTICULARLY useful is me sitting between you and Chauss. =D> :lol:
How many guys will be in the room? It is not like we will all be in lines at desks like in a class room.
Now I am even more worried -- :(
Post by BillD » Fri Aug 19, 2011 6:08 pm
Hemostats are the clamps that pinch off blood vessels during surgery. They can clamp onto most things, and are useful for working on electronics.
Post by OconeeOrange » Fri Aug 19, 2011 6:33 pm
Another $12 bucks. You guys are breaking my bank nickle at a time.
http://www.amazon.com/SE-Forceps-Straig ... 590&sr=8-4
On the way -- =D>
This thread has been soft edited so that we can stay on topi
Post by treitz3 » Mon Aug 22, 2011 2:05 pm
hewlew1 wrote:Just as a point of clarification there are 2 conflicting post listed on the forum one states that the tubes are 12AX7's the other states that the tubes are 6AX7's. I would assume that since the output tubes are 6BQ5's that the heater filiment voltage from the transformer is 6 volts. Which would make the correct tubes 6AX7's. Is this correct?
I do believe that we can wire it up both ways for whichever tube you wish to use. Let me verify this....
Post by BillD » Mon Aug 22, 2011 2:27 pm
The 6AX7 is a very odd tube. Another dual triode probably. Maybe a 6DJ8?
Damn, this is a long thread...
Post by treitz3 » Mon Aug 22, 2011 3:18 pm
I finally found it....
gerberj wrote:Hello all,
Sorry for taking so long to reply. I have just confirmed with Bob that you will definitely be able to wire up this amp for use with the 12AX7 if you so desire. However, they are still coming standard with the highest quality 6AX7s. Either way, your amp will sound wonderful. We have designed it around the 6AX7, and as I have previously stated the distortion is outrageously low for that reason. If somewhere down the road you wish to change from using the 6AX7 to the 12AX7, or vice versa, it is an easy change that will take all of 10 minutes.
-Jordon
Post by treitz3 » Mon Aug 22, 2011 3:23 pm
BUT....when I look at the first post on the thread, I see this.....
The tubes needed will be:
(x4) 6BQ5 or 7199
(x2) 6AX7
or is it....
12AX7 and 6AX7s? This will be confirmed shortly.....damn, you think this would be an easy question to answer. #-o
Post by Eddie » Mon Aug 22, 2011 7:01 pm
(4) 6BQ5=7199
(2) 12AX7=ECC83=E83CC
Post by OconeeOrange » Tue Aug 23, 2011 8:23 pm
For the "hot house" Carver Amp building day, got in 6 gallons of Lipton Tea and a case of Pepsi today. If anyone could help with some more or some ice, that would be good. I guess bringing your own cup is a given.
Return to “CarverFest 20w Tube Amp”
