Re: Carverfest Tube Amp upgrades Please post ideas.
It is currently Wed Jun 19, 2013 12:59 pm
Chauss wrote:I think the point to consider is that you can use RCA to XLR cables and have the same result- no need to put XLR connectors on the amp.
TNRabbit wrote:Balanced lines run @ 10dB down from RCA, but when summed back together at the end, they have the same output. When you use an adapter, you lose half that summing & get a much reduced output level.
Chauss wrote:All depends upon the cable quality- no? If you do not let noise in- it was there to begin with...
http://www.amazon.com/Mogami-Gold-XLRM-RCA-06/dp/B001LNN2GE
mbskeam wrote:this is a mono/stereo switch
no need for Y cables and the jumper between the Pos. speaker leads
got the word from a good source that some of the hum issues may be from the power transformer coil and OPT being all in the same line, N\S. poles. the one closest to the PS.
so I whipped up these little fellas, this will put the OPT at 90deg and 90deg flat to the PT, this should help.
stock cover will fit also....
