It is currently Sun May 19, 2013 3:06 am
adding LED's to CarverFest 20w amp
Post Mon Sep 26, 2011 10:43 pm
you should get 3.0v across the led, the ones I used did not like much more than 3.5V, poof if you went much higher.....
http://www.radioshack.com/product/index ... PerPage=60
if you used the white tube bases you will have to source 3mm dia leds, also you will have to take out the center connector, use a small drill bit to remove the swedged out part, then you can push the rest of the barrel out.....
jerryj12
Post Mon Sep 26, 2011 11:44 pm
Re: adding LED's to CarverFest 20w amp
Thanx Mike !!!
Post Mon Sep 26, 2011 11:57 pm
You have a link or something to the ones you used? Not necessarily the same color. Just as a FYI
Post Tue Sep 27, 2011 10:06 am
Thank you, Mike. This is something that I plan on doing to both of my amplifiers.
