It is currently Sat May 25, 2013 2:08 pm
Update from Bob
Post Wed Oct 26, 2011 1:08 am
Update from Bob
Hi Carverfest tube amp builders,
As you may remember, the amps we built were flawed because the tubes were not reliable, and the bias regulator zener diodes blew up about half the time. So I just cut them out and built the amps without them. Since I did not have good tubes with me, We tested the ones I did have and the ones that seemed okay were the ones we used.
These desperate decisions yielded an amp that was okay, but not as spectacular as it should or can be!
Here is the latest:
I tested lots of output tubes and found out something I did not know. I found out that some EL84/6BQ5 tubes are rated for 550 volts, and others are rated for 300 volts.
Most American 6BQ5 tubes are good for 300 volts. I thought a 6BQ5 was a 6BQ5 and good for 550 volts. Not true. This amp runs at 425 volts, and if you use a 300 volt tube, they tend to run away and glow cherry red. Not good! Amperex are the best, and can easily take even a thousand volts, whereas the ones we used at Carverfest are good for only 300 volts. Even the great Telefunken tubes are good for only 300 volts. So don't use them. You will be tempting fate. Mullards are good for 550 volts.
The tubes to use are the brand new Sovtek 6BQ5/EL84 tubes sold by Electro - Harmonix. I have tried them for extended time periods, fifty of them to be exact, without a single failure. That compares with about one in three failures for the Red Army tubes (300 volts) that I got for a buck or so. These EH tubes sound great and are superb tubes. You can get a matched quad for about $29 dollars, or about $7.25 dollars each. They are almost as good as Amperex. Buy them for your Carverfest amp! eBay item number 290613742187.
The next item is the bias regulator. Get a single 15 volt, 5 watt zener and install it across the 220uf/35 volt cathode bypass capacitor. This capacitor is in the cathode circuit of the four 6BQ5 output tubes. Solder the cathode end (the band) to the + end of the capacitor and the anode end to the - end of the capacitor. The schematic you have may show two 7.5 volt zeners, or I might have erased your copy. In any event, the circuit should be a 15 volt, 5 watt zener across the 220uf cap.
Buy it at any on-line place like Parts Express or Mouser. The brand is Micro - commercial, part number 1N5352B - TP, 5 watt zener. Cost about 55 cents.
These changes will make the amp sound the way it should. The bias regulator especially!  Without it the bias floats all over the place and the amp sounds mushy. With the regulator working the amp gets a better soundstage, greater depth, sweeter imaging; even the presentation will be wider and more detailed. I wish the ones I brought to Carverfest had worked. They got to me the day before I left, and I did not have the time to try them, but I thought they would work. Oh well.
Bob Carver
Post Wed Oct 26, 2011 1:23 am
Re: Update from Bob
James, Alex posted this a few days ago if you are not aware of this? otherwise nevermind as probably best to be in its own thread!! :D
Post Wed Oct 26, 2011 7:55 am
Re: Update from Bob
That's what a "relationship" can do for ya... :lol: :lol: :lol:
Post Wed Oct 26, 2011 8:52 am
Re: Update from Bob
Is anyone here willing to /going to make a "group buy" (ie qty) and postal mail these out so everyone does not have pay $10 shipping charges for $1 worth of parts?
Post Wed Oct 26, 2011 9:29 am
Re: Update from Bob
Actually, it so you don't have to find it in another thread.
Post Wed Oct 26, 2011 3:32 pm
Re: Update from Bob
Post Wed Oct 26, 2011 8:05 pm
Re: Update from Bob
let me know, as i will get them and send out.
Post Wed Oct 26, 2011 8:07 pm
Re: Update from Bob
never mind, i will get a bunch. pm the address they will go to.
Post Wed Oct 26, 2011 8:25 pm
Re: Update from Bob
angelod307 wrote:never mind, i will get a bunch. pm the address they will go to.
PM sent
Post Fri Jan 13, 2012 12:59 am
Re: Update from Bob
any new news on the tubes for the amps? i sent a pm to the store bob mentioned for 8 quads pricing. anybody else need some ? maybe i can get a better price on them right.
Post Fri Jan 13, 2012 4:34 pm
Re: Update from Bob
so, the price is 5% off with a shipping charge of 20.43 for a total of 240.75. next i asked how many do i need to order to get a 20% discount, and we will see. $30.09 per set shipped. almost free shipping.
Post Fri Jan 13, 2012 5:37 pm
Re: Update from Bob
keep us up to date Angelo I may want 4 quads if the price is right. This tube rollin shit is a bitch!
basspig
Post Sat Jan 14, 2012 4:19 am
Re: Update from Bob
Good grief, it sounds like Bob is just 'guessing' instead of referring to the tube manual for design center and design maximum ratings. For heaven's sake, when you design a tube amplifier, you operate the tubes at their 'design center' values, or else the tube life will be GREATLY shortened.
The plate dissipation on this tube is ONLY 12 WATTS. Class AB1 operation, design center is 250V plate and screen grid. Cathode current is only 45ma.
Running this tube at 500 volts is foolhardy and, for a commercial product, downright irresponsible!!
Take care,
Mark & Mary Ann Weiss
Business sites at:
http://www.ampexperts.com
http://www.mwhdvideo.com
Post Sat Jan 14, 2012 4:27 am
Re: Update from Bob
basspig wrote:Good grief, it sounds like Bob is just 'guessing' instead of referring to the tube manual for design center and design maximum ratings. For heaven's sake, when you design a tube amplifier, you operate the tubes at their 'design center' values, or else the tube life will be GREATLY shortened.
[-X
:-k
The bobfather has spoken. no one is perfect, just human. what i paid for the amp was a privilege for getting to hang out and talk shop. i tell you it was priceless although there was a amount that i spent. i would do it again.
Post Sat Jan 14, 2012 4:32 am
Re: Update from Bob
oh yeah, i may be a little biased though. :-"
