Help troubleshooting CF amps.....
Post by TNRabbit » Tue Jan 24, 2012 12:01 am
....I'll get pics up in the next couple of days, but I have 3 of the 4 amps done & have different issues with each:
1. Built at CF, Bob certified it, sounded good when I left. I added a couple of circuits that Alex said I left out & now has hardly any output which is GREATLY distorted.
2. Built at home; sounds pretty good, but have massive buzz (ground loop)....tried removing the neutral leg but no joy....
3. Tried to plug in the input & got a spark; have a few DC volts on the GROUND of this circuit! WTF???
Ideas?
Re: Help troubleshooting CF amps.....
Post by mbskeam » Tue Jan 24, 2012 12:15 am
parts in the wrong place???
Post by TNRabbit » Tue Jan 24, 2012 12:26 am
mbskeam wrote:parts in the wrong place???
It was my understanding that resistors don't have to be put in a particular direction....?
Post by treitz3 » Tue Jan 24, 2012 12:29 am
Yes, resistors are uni-directional. Not that that helps with the troubleshooting at all.
Post by angelod307 » Tue Jan 24, 2012 12:44 am
Post by mbskeam » Tue Jan 24, 2012 12:51 am
I'm being serious.
I think ya have something in the wrong place
there are 47ohm 470ohm and 47kohm resistors, do you have them in all the correct places?
do you have the small caps in the right place, the 100pf and the .0047uf?
as to the dc on the input, do you have a glob of solder bridging or touching some place it should not be....
bad rca input?
not sure about the hum, if you swap the PS transformer it may go away.
Post by TNRabbit » Tue Jan 24, 2012 1:18 am
I know; I've looked at all the amps & they are the same except a few resistors in opposite direction.
By swap the PS, you mean the leads or the entire PS?
I'm wondering if there's an issue with the cheap-ass RCAs I used on the stainless chassis amps......
Martin1970
Post by Martin1970 » Tue Jan 24, 2012 9:04 am
TNRabbit wrote: I'm wondering if there's an issue with the cheap-ass RCAs I used on the stainless chassis amps......
Not that this matters to your issue, but my RCAs stripped and it loves to cut up until I retighten them to that 'magic spot' where they grip just enough. Been looking for better replacements, but the ones at PE look like they're the same ones.
How about linking to some comprehensive pics of your troublesome amp.
You know, another set of eyes and all that...
Post by TNRabbit » Tue Jan 24, 2012 10:01 am
Martin1970 wrote:How about linking to some comprehensive pics of your troublesome amp.
TNRabbit wrote:....I'll get pics up in the next couple of days, but I have 3 of the 4 amps done & have different issues with each:
Ideas?
Post by TNRabbit » Tue Jan 24, 2012 11:15 am
OK, had some time, so here are pics:
Amp 1:
Amp 2:
Amp 3:
Post by engtaz » Tue Jan 24, 2012 11:56 am
SSS WWW EEE EEE TTT job Gary. Im jealous because I have not even started my last 2. :x
Post by elgrau » Tue Jan 24, 2012 12:25 pm
"Oh what a tangled web we weave...."
I think I'd send one off to Rita/Rolland and then meticuloiusly check to make sure that the other two(?) are wired exactly like this one that he/she sends back that now works. Check every terminal strip/tube socket/juncture and verify that the parts eminating from each is the same (as the working amp). Being unemployed you should have the time for this.... :D
Post by hewlew1 » Tue Jan 24, 2012 12:42 pm
Gary, I think I see in the various photos some cold solder joints as well as some joints that are not what you would call mechanically solid( wires not wrapped and squeezed with needle nose pliers around the terminal strip lugs).I would spend a little time touching up the solder joints this may help.Good luck, Harry
Post by hewlew1 » Tue Jan 24, 2012 1:04 pm
Gary, I have another suggestion . I can see you are building these as monoblocks but for the purpose of troubleshooting I would remove the jumper wire between the 2 red speaker terminals and hook up 2 speakers to each amp. You may indeed have one channel that is working correctly but bridged together you cant tell this. If this is the case it is much easier to troubleshoot the one channel that has a problem. Harry
Post by mbskeam » Tue Jan 24, 2012 10:59 pm
this area is the problem ....
need a better pic, push the wire out of the way and try and bend all the parts, so that they do not overlap in the pic to get a better view.
does that tag strip have parts soldered to the ground lug on the end???
you have 5 of lugs used, on mine I have 4 used. no parts should go to on this ground on this strip, except the ground going back to the main ground point, over at the PS area
amp 3 looks the same.... on this tag strip
this 47 ohm res goes back to here
???? the cap that is circled is this the smaller of the 2 (100pf)
Return to “CarverFest 20w Tube Amp”
