It is currently Sun May 19, 2013 1:54 pm
Carverfest Amp Tube Supernova
Martin1970
Post Tue Jan 31, 2012 1:29 pm
So, these are the Sovtek eBay tubes Bob suggested.
These had been running hard earlier, the temp at that time was 360 degrees.
They were turned down when this happened.
They were still playing and sounded fine.
What caused this?
Is it dead?
Found this: http://en.wikipedia.org/wiki/Glowing_plate
from that, overcurrent
Wonder if overvoltage failure is same deal since these things are operating outside of their range.
Rane: RPM88 26Z x3
Post Tue Jan 31, 2012 1:57 pm
Re: Carverfest Amp Tube Supernova
Shitty build quality~
Post Tue Jan 31, 2012 1:59 pm
That is not good. I would replace that tube and possibly not run the amp until you figure out if the tube just failed or there is a issue with the amp. Tubes going supernova can damage other components or speakers.
Martin1970
Post Tue Jan 31, 2012 2:01 pm
TNRabbit wrote:Shitty build quality~
Of course!
That's what I get from copying the rabbit :rolleyes:
Rane: RPM88 26Z x3
Martin1970
Post Tue Jan 31, 2012 2:02 pm
Snoop65 wrote:That is not good. I would replace that tube and possibly not run the amp until you figure out if the tube just failed or there is a issue with the amp. Tubes going supernova can damage other components or speakers.
It was part of a matched quad....doh!
Rane: RPM88 26Z x3
Post Tue Jan 31, 2012 2:04 pm
Kinda looks like Mike's amp with the LEDs , but only on 1 tube....kinda..... :-"
Martin1970
Post Tue Jan 31, 2012 3:50 pm
Rane: RPM88 26Z x3
Post Tue Jan 31, 2012 4:02 pm
It doesn't look good...
that sucker is NUCLEAR!
Post Tue Jan 31, 2012 4:39 pm
That's called "tube orgasm syndrome". Stop playing so much sexy female vocalist type music and it will subside.....and then the tube will simply go to sleep!
^ add: above video.....LMAO!
Martin1970
Post Tue Jan 31, 2012 4:41 pm
I love you guys.
EDIT begging: But really, what's wrong with my poor amp?
EDIT: I think I finally found my avatar
Rane: RPM88 26Z x3
Post Tue Jan 31, 2012 4:59 pm
I have no idea what to tell you, Martin; hence, the silly replies. I'd guess bad tube. It happens. Not like they were $50 each....
tinpan has the same tubes....better keep an eye on them, Robin!
Post Tue Jan 31, 2012 5:01 pm
I really think the issue is the voltage, it's at the very top edge of the spec, and outside of some tubes by about 100V...
the only tru way would be to drop the voltage into a zone that would allow you to roll other tubes.
as you know if you do this, a few resistors will have to be changed
and a diffrent transformer. will it change the sound. I dont know.....
on the web sites schematics it shows a lower voltage, not the 420v or so that you have to start out with....
Post Tue Jan 31, 2012 5:03 pm
Martin,
I have the Mullards in mine per Dan's recommendation. So far, no problem with the tubes.
Post Tue Jan 31, 2012 5:11 pm
mbskeam wrote:I really think the issue is the voltage, it's at the very top edge of the spec, and outside of some tubes by about 100V...
I have 470 volts on my tube circuit.... :shock:
Martin1970
Post Tue Jan 31, 2012 5:13 pm
OK, so now the plan is to find a couple of quads of 500+ volt rated EL84s.
I'll look into the Mullards.
Maybe the Yen Audio guys have an idea, too.
Rane: RPM88 26Z x3
