Cartridge loading the Sunfire Tube Pre
Post by Magnaryder » Sat Dec 07, 2013 1:51 pm
In my quest for better sound through correct system set-up I did some research on my phono cart and found it needs 400-500pf of loading. Anyone know how to accomplish this? Looking around the net I've noticed the BigDog(big$$$) phono pres have switchable capacitance and resistive loading.
I've installed 3 deParavicini EI 7DJ8s on the main board and 4 on the phono board. I still have the stock 12AX7s on the phono board. How significant could a tube change here be?
Re: Cartridge loading the Sunfire Tube Pre
Post by kingman » Sat Dec 07, 2013 2:38 pm
I don't know but am interested in your findings Ray. I'm plannning a tube swap soon and have some gold pin Amperex. Wondering the same in the phono stage. :-s
Post by Zoot Horn » Sat Dec 07, 2013 3:51 pm
kingman wrote:I don't know but am interested in your findings Ray. I'm plannning a tube swap soon and have some gold pin Amperex. Wondering the same in the phono stage. :-s
Are these the ones that I hooked you up with 2 years ago?
Post by kingman » Sat Dec 07, 2013 4:34 pm
I knew your memory was that of an elephant!!!! :lol: :lol: :lol:
Post by Zoot Horn » Sat Dec 07, 2013 4:54 pm
I can't decide if you should be ashamed ,,or,,just too much gear--Happy Holidays to you and Tammi. Pm me your addy--- I'll send you some special white gloves,,if and when you decide to pop em' in. =D>
Post by kingman » Sat Dec 07, 2013 5:50 pm
Zoot Horn wrote:I can't decide if you should be ashamed ,,or,,just too much gear--Happy Holidays to you and Tammi. Pm me your addy--- I'll send you some special white gloves,,if and when you decide to pop em' in. =D>
George...thanks for the offer but I'd rather see your magic walk through the screen door....I did that also last year BTW!!!! :shock: :lol:
Post by Zoot Horn » Sat Dec 07, 2013 5:54 pm
I got caught doing alot of things last year too.
Post by radioeng2 » Sat Dec 07, 2013 6:06 pm
Magnaryder wrote:In my quest for better sound through correct system set-up I did some research on my phono cart and found it needs 400-500pf of loading. Anyone know how to accomplish this? Looking around the net I've noticed the BigDog(big$$$) phono pres have switchable capacitance and resistive loading.
Ray the capacitance effects high freq peaking. I used to use a test records and do sweeps and dial in the capacitance while watching the HF response.
In you want to do it with numbers, then you want to know how much capacitance the input presents along with your cabling. Then for neutral freq response, you'd need to add that value. The easy way to do that is use a RCA T. On the extra arm add on a simple RCA male you've tagged an appropriate value cap on.
Before you bother, you need to run a sweep record and see what your response really is. Generally when people are going on and on about how a cartridge sounds, part of what they actually are referring to is how close the built in values match the cartridge. Loading is more than just resistance.
Changing tubes by the way is likely to also be slightly altering the presented capacitance. If you look at the spec sheet for tubes, you can see a listed input capacitance value for the grid.
Post by frenchguy » Sat Dec 07, 2013 7:11 pm
yes you did george! :lol: maybe you & wayne can do a tandem screen door illusion @ CF14 :lol: :lol: :lol:
Post by Snoop65 » Sat Dec 07, 2013 9:13 pm
Ray there are small jumpers on the phono board you can move around to change the load. Also if you are using a moving magnet or moving iron cartridge you are listening through the 12ax7 tubes. The 3 6dj8/6922's at the rear are for the moving coil section. And you will hear a difference rolling tubes in the phono stage.
Post by Magnaryder » Sun Dec 08, 2013 12:05 am
Vance thanks for the pointer. Looking for jumpers wouldn't have occurred to me.
I'm about a dumbass. I broke my own rule of never working on anything(particularly important on motorcycles) without a service manual. Anyone have a .pdf of the owners manual they could email me? Maybe I'll learn something new about my Sunfire pre.
Post by Snoop65 » Sun Dec 08, 2013 1:16 am
Magnaryder wrote:Vance thanks for the pointer. Looking for jumpers wouldn't have occurred to me.
I think you can download the manual from the other Carver forum. If not let me know i'll scan and upload mine.
Post by Magnaryder » Sun Dec 08, 2013 2:03 am
I found the manual and printed a copy of it. Thanks Vance!
Looks like changing the 12AX7s will yield the best results.
Suggestions anyone? I think I will try some vintage 12AU7s I have from the late 50s if I read the date codes correctly.
Buckeyes lost to Michigan State. They cost me alot of money. I would have been giving any takers Ohio State and at least 7 points against Florida State. I really wanted to watch FSU humiliate them. DAMN!!!! I made a bunch the last time these 2 played.
Post by MRHP » Sun Dec 08, 2013 9:50 am
Ray you should definately roll some tubes. If you will pm me your address I will send you a few selections to try out and see whay you like.
BTW you are on the right track with 1950's 12au7's. You will lose some gain but some of the 12AU7's sound awesome. Dont forget that a 5751 will also work in that socket.
Post by BrianT » Sun Dec 08, 2013 10:05 am
Ray
Where you a sleep when we where talking on the phone, I told you to set the jumpers to 47K on the board
also my buddy Mike told you the same.
