Is it safe to bridge my Sunfire amp?
Re: Is it safe to bridge my Sunfire amp?
Post by Magnaryder » Wed Jan 29, 2014 9:34 pm
hewlew1 wrote:Califorification
Frankied knows all about this term. \:D/
yeah but he's forgotten what it means. too much box wine.
bwaahahahaha
Post by angelod307 » Thu Jan 30, 2014 12:01 am
Yes , with two cinema grands, he has two two channels with resistors . So one amp left and one right via resistance provided. Only resistor channels can be summed. That is my theory applied from the two channel manual.
Post by angelod307 » Thu Jan 30, 2014 12:06 am
Now on that ten times the power , negative. You need six to ten db depending on frequency for perceived double in loudness. So then three db is achieved when you double power from say 1 watt to two watts. It can also be doubled by twice the area radiating via two speakers with the same impedance . Now double a speaker by adding another in parallel then you also half the impedance which also adds three db of power for that predictable output .
Post by TNRabbit » Thu Jan 30, 2014 6:48 am
angelod307 wrote:Yes , with two cinema grands, he has two two channels with resistors . So one amp left and one right via resistance provided. Only resistor channels can be summed. That is my theory applied from the two channel manual.
So you're willing to bet that your supposition won't leave the OP with a melted amp?
Carv-it-up
Post by Carv-it-up » Thu Jan 30, 2014 10:39 am
I think I'm going to leave things the way they are unfortunately. I don't want to mess up my amps or my speakers when I'm not hundred percent sure that this would work. The doubling of power would have been nice for the added headroom, but it's not crucial. If anyone has Bob's number and can ask the specific question I have posed here about the CG's, I would deeply appreciate it. Thanks.
Two Signature Cinema Grand Series II amplifiers (both are used in bi-amping my Infinity IRS Beta speakers)
Cherry 180's (use them off & on to power the mids/highs tower of IRS Beta speakers)
Sunfire Signature 600~Two amplifier (used on Thiel CS5i)
Carver TX-12 tuner
Own & working, but not in use right now - Sunfire Series II amplifier + two Carver M500t MKII amplifiers + Sunfire Classic Vacuum Tube Preamplifier preamp w/ phono & remote.
Post by jjptkd » Thu Jan 30, 2014 1:42 pm
Sounds to me like you have 400 watts available for each woofer... :-k :-k Can you power each woofer separately?
Oppo Sonica DAC
Sunfire TG-IV
Sunfire 325x2
Customized Klipsch RF-5's
Carv-it-up
Post by Carv-it-up » Thu Jan 30, 2014 3:51 pm
No I cannot power each sub separately. What I could do later on down the road is wire each of the 4ohm subs in parallel to produce and one ohm load to the one channel that I'm using from my cinema grand amps. I was just in hopes that it would be an easier route bridging amplifier. What I would like to know is with a one ohm load will the sound change? I believe I read somewhere that the lower the impedance, with woofers, the muddier the sound.
Carver TX-12 tuner
Carv-it-up
Post by Carv-it-up » Thu Jan 30, 2014 3:52 pm
I am trying to avoid altering the wiring of the speaker if I can.
Carver TX-12 tuner
Post by TNRabbit » Thu Jan 30, 2014 3:54 pm
One ohm load wouldn't be good.
you'd be better off separated the driving each one with 1 channel
Carv-it-up
Post by Carv-it-up » Thu Jan 30, 2014 4:53 pm
Mmmm taps for each speakers sounds like it would be the best way to go if bridging can't be done.
Carver TX-12 tuner
Post by frankieD » Thu Jan 30, 2014 5:30 pm
Carv-it-up wrote:No I cannot power each sub separately. What I could do later on down the road is wire each of the 4ohm subs in parallel to produce and one ohm load to the one channel that I'm using from my cinema grand amps. I was just in hopes that it would be an easier route bridging amplifier. What I would like to know is with a one ohm load will the sound change? I believe I read somewhere that the lower the impedance, with woofers, the muddier the sound.
A "one ohm load" will pretty quickly produce the sound of an amp burning up.
Post by MRHP » Thu Jan 30, 2014 6:44 pm
I have been told the Lightstar will run 1 ohm with ease and even drop into 1/2 ohm teritory without any trouble. Any truth to this?
Post by Snoop65 » Thu Jan 30, 2014 6:50 pm
MRHP wrote:I have been told the Lightstar will run 1 ohm with ease and even drop into 1/2 ohm teritory without any trouble. Any truth to this?
Yup! :D
Carv-it-up
Post by Carv-it-up » Thu Jan 30, 2014 7:13 pm
I thought the Sunfire was just as stable into low low impedance as the Lightstar?
...matter of fact, I have an article that says the Sunfire Sig. was used at 0.5 ohms for shaker boxes with no problems, but burnt-out meter light bulbs. I guess I can't believe everything that's printed in a magazine.
Carver TX-12 tuner
Post by Snoop65 » Thu Jan 30, 2014 7:17 pm
Carv-it-up wrote:I thought the Sunfire was just as stable into low low impedance as the Lightstar?
The Lightstar is a different beast. The Sunfire has to be modded for 1 ohm operation.
