Signature 600x2 issue....
jstang
Post by jstang » Sat Jun 28, 2014 10:03 pm
Hey there folks.... Hello.... I am a long time lurker....
I am working on a Signature 600x2 for my friend Eddie, he is on this site.... his is a long time Carver/Sunfire audiophile.... I am new to this site, but he is an old timer and visits Carver Fest ....
Anyways, I am looking for advice on a Signature 600x2 that had seeming had CAP go up in smoke and take out some small signal xtors... Take a look at the pics .... Any advice? Or schematics? Seen this before? I am guessing the cap blew, shorted and took out a few other parts...
Thanks,
Johnk
Re: Signature 600x2 issue....
Post by frenchguy » Sat Jun 28, 2014 10:27 pm
what pics? :?: :-? :)
Post by Eddie » Sun Jun 29, 2014 8:57 am
Here is one of the channel boards!
Post by frenchguy » Sun Jun 29, 2014 9:20 am
Ouch!! :shock: magic smoke!! #-o lots of damage there, dont know if that board can be repaired? [-o< :-k
jstang
Post by jstang » Sun Jun 29, 2014 9:50 am
Odd I see the pics... Might be my loggin at the other site that allows that. Anyways thanks for reporting the pics... And yes to ouch....
Good news is I can just copy the other channels parts value, but a schematic sure would help.
And Wisdom/advice is never turned down....if someone has seen this issue before.
JohnK
Post by frenchguy » Sun Jun 29, 2014 9:56 am
pretty sure sunfire has never released schematics for any of their equipment!! ](*,) should be able to identify the pieces you need & replace though! :-k
Post by Zoot Horn » Sun Jun 29, 2014 10:36 am
Damn,, what were you doing,, arc welding with it,,,seriously,,hope you get it repaired !
Post by radioeng2 » Sun Jun 29, 2014 10:46 am
My gut feel is overvoltage to the capacitor from something else failing. Looks kind of far away from the higher heat sources to be the first electolytic to give it up. I'd look real hard at all the semi-conductors there. Look for a likely path for voltage exceeding the cap rating.
Pull the same circuit caps in the rest of it and look at them real hard as a cross check. I'd consider wholesale replacement of the electrolytics though if it's time.
Wear out your VOM doing cross checks. Good luck!
Post by jjptkd » Sun Jun 29, 2014 11:54 am
So you ended up with the Silver 600 two that was on eBay... :-k :-k Good luck with the repair!
Oppo Sonica DAC
Sunfire TG-IV
Sunfire 325x2
Customized Klipsch RF-5's
jstang
Post by jstang » Sun Jun 29, 2014 11:58 am
Yup... One of the small signal xtor next to the cap are blown out too.... Chicken or egg?
I will clean and inspect it this evening, once Eddie stops calling me and asking "Is it fixed yet?" :D :D :D
JohnK
Post by OconeeOrange » Sun Jun 29, 2014 4:32 pm
I believe many can work on these, but while I mean no disrespect to you, Bill Flannery is the best available now.
http://www.flannerysvintageaudio.com/
In my opinion, the guy to contact before any Sunfire purchase or repair is Jessie. He is free help and knows his crap. The guy is an expert who is actually available =D> .
I have 7 Sunfire amp things (bidding on another against Jessie as I write this).
Anything I really want, I contact Jessie (jjptkd). He has a 100% satisfaction policy.
Looks like your motherboard is shot. You may have a unit to sell as parts on ebay as there is a market.
jstang
Post by jstang » Sun Jun 29, 2014 6:29 pm
Well all I really need is a schematic.... I will be good to go.... I have worked in the electronics field for 40 years.
There are burnt runs near that cap, even those can be repaired. It will be a little scared when done, but will sound just fine.
So I take it , this is not a common issue. Oh well....
JohnK
Post by angelod307 » Sun Jun 29, 2014 9:35 pm
The only people that have those schematics are as follows,sunfire, bob carver, bill Flanery I would think( do not know for sure) and tom at vintage hifi. That is it. Rolland most likely made a schematic as he also works on the. Sunfire. No one I know of has them to give. So. I may be a touch prejudice as I have had all four people work on my amplifiers at one point or another. They all are top rate. For me, my two lightstars are being rebuilt by Tom who also has that paper work as well. Hard choice, but I like the tom. Next would be Rolland, then bill and bob is way too busy.
Post by angelod307 » Sun Jun 29, 2014 9:38 pm
Curious, as I must have missed it, how much did a silver 600 cost you if you don't mind sharing?
Post by jjptkd » Sun Jun 29, 2014 9:48 pm
I bid it up to $950 shipped and he out bid me by $10? Somewhere right around there, under $1k shipped. I would have bid more as I know this would be an easy fix for Bill as he has a stack of brand new replacement boards for this amp but I'm working too many hours right now to do any serious eBay battles. Bill is the man with the Sunfires as he has the schematics, parts and the experience. This probably would have been a $300 repair with less than a week turn around through Bill, just sayin'. :? :?
Oppo Sonica DAC
Sunfire TG-IV
Sunfire 325x2
