Anybody adjust the gain on a Sunfire 300 x 2 Amp?
Miko1971
Post by Miko1971 » Sat Jan 17, 2015 2:29 pm
Hello,
In the owners manual it states that you can increase the gain 12.7db by connecting a jumper across the JP1 point on the circuit boards of each channel.
anyone try that?
Re: Anybody adjust the gain on a Sunfire 300 x 2 Amp?
Post by angelod307 » Sat Jan 17, 2015 8:04 pm
Nope, not me.
Post by elgrau » Sun Jan 18, 2015 9:43 pm
Nope....has more than enough gain as is for my ~4 ohm impedance sphere's....
Must be something lost in doing this otherwise why would it not be the baseline configuration? [-X
If it ain't broke....would be my reason for not messy around with this, but if you try it, I'd be interested in what you find out.
fill35U
Post by fill35U » Sun Jan 18, 2015 11:46 pm
12.7dB is a lot! 500mV RMS sensitivity?
Just curious, but are you trying run a Sunfire amp directly off an iPhone?
Post by radioeng2 » Mon Jan 19, 2015 9:06 am
Also, remember that gain is not going to change how much power is possible from an amp unless you can't get enough level as is.
I find to much gain in amps is normal. I do not desire to have the preamp knob in the lower area for normal use. I'd prefer more like about 3/4's up...leaving a little more if needed. Any less and you are paying something of a noise penalty.
It's routine to see misguided people equate amp gain to some kind of quality thing. The "I got a powerful new amp and now I only have to turn up the volume to half way to blow me out!" FIrst, again, that's not power, that's gain. And second it tells you it's a mismatched system and they are getting less quality than they could be.
That may not at all be where you're headed, but this seems like a good place as any to blow off about this common thing.
Post by Chauss » Mon Jan 19, 2015 9:53 am
Studies have shown that louder / more powerful = sounds better (in most minds). Sadly this is how most folks generally judge systems also.... #-o
-If it plays louder than live......you have to be adding something that is or was not there to begin with in the original recording (over amplification of the signal). :-s
Miko1971
Post by Miko1971 » Mon Jan 19, 2015 10:48 am
I run the Classic Vacuum tube pre so it's not mismatched. I was just curious if anybody had ever tried it since it was an option to do so. for my listing level's i have the gain at almost the maximum. i was thinking that increasing the gain would allow for finer adjustment of volume by not running it all the way over.. one i get my pre amp back from audio horizons, i'll see if that didn't help any. plus roll in some Telefunken NOS tubes i have sitting here.
