The Mother of all Sunfire Vacuum Tube Pre Amp Upgrades
Miko1971
Post by Miko1971 » Sun Jul 19, 2015 12:52 pm
THE MOTHER OF ALL UPGRADES.....
Here is the Upgrade breakdown:
1. 4 toggle switch upgrade to ARC style flat paddle.
2. Replace fuse holder and install AH Platinum reference fuse
3. Upgrade Internal 2 main signal/power wiring buss with Hi Q silver wires
4. 6 Vishay naked Z foil resistor's
5. 4 Vibrapod isolator's and add EAR isodamp SD 40AL inside of chassis and center part of top inside cover.
6. Alps motorized volume pot with remote. Remove the cable buss and other components to all fit in plus add the infrared remote sensor and the driver
assembly PCB, R.C components, wiring harness.
7. Remove AC outlets, install metal block off plate and paint black.
8. Replace 3 main signal tubes with NOS.
9. 2 Bybee music rails on line stage.
10. V cap CuTF, 4 of 1uF and 2 of 0.22uF.
11. Tube base power supply which include's Premium power transformer, tube rectifier, choke,tube voltage regulator, 2 power tubes
12. Azuma silver ceramic tube sockets
13. Drill 5 tube holes on top of cover and black color touch up
14. Power diodes to FRED soft recovery type, remove the stock power cord to install Furutech AC inlet.
15. original repair of pcb board.
All work being performed by Joseph Chow of Audio Horizions.
http://www.audio-horizons.com/
Re: The Mother of all Sunfire Vacuum Tube Pre Amp Upgrades
Post by radioeng2 » Sun Jul 19, 2015 12:58 pm
Maybe..."The Preamp Formerly Known As Sunfire Vacuum Tube Preamp" would be most appropriate! =;
That's quite an upgrade. Should be even more remarkable. What a list!!
pmat
Post by pmat » Sun Jul 19, 2015 4:20 pm
Wow, awesome plan. By the way I still hate your avatar, It freaks me out. Guantanamo torture for sure.
Retriever
Post by Retriever » Mon Jul 20, 2015 8:25 am
Impressive list! I'd like to hear your review when its done!
I 've used FRED diodes in the "downtracker" (smps supply) in my 3 MKII subs and reduced the noise component.
Never thought of using them in a 60 hz supply seems like overkill, but from an audiophile perspective sounds great lol.
Excess performance is good!
Post by MRHP » Mon Jul 20, 2015 1:49 pm
Pics man we need pics!!!
Miko1971
Post by Miko1971 » Mon Jul 20, 2015 4:12 pm
I asked J.C. To send pics as he builds it.
Miko1971
Post by Miko1971 » Wed Jul 22, 2015 12:29 pm
Okay I think it might be time for an intervention! Talking with Joseph we are deciding to add WBT NextGen Silver RCA Chassis plugs and I'm considering having him add in his TP 8.1.1 Phono Board while he has it there:
http://www.audio-horizons.com/pages/phono.html
This would address the two features I didn't order when I bought it new, a remote and a phono stage.
What do you guys and gals think? Good idea or am I in need of counseling?
save me from myself!!
Post by Snoop65 » Wed Jul 22, 2015 5:11 pm
Miko1971 wrote:Okay I think it might be time for an intervention! Talking with Joseph we are deciding to add WBT NextGen Silver RCA Chassis plugs and I'm considering having him add in his TP 8.1.1 Phono Board while he has it there:
I'm on the fence about the RCA's but I would go for the phono stage.
Post by Snoop65 » Tue Aug 11, 2015 7:12 pm
Any updates? :-k
Miko1971
Post by Miko1971 » Wed Aug 12, 2015 8:18 pm
Why yes! With pictures no less!!
The V-Caps have been installed, looks like he is working on the WBT RCA jacks as well. I think that those are also the ceramic tube sockets. He did say that he had to custom fit the new toggle switches, those were a big pain in the ass it seems. Had to be filed and fitted all by hand. I tell ya, this is gonna be something else when its all said and done. $$$$.
Post by Snoop65 » Wed Aug 12, 2015 8:53 pm
Wow!!!! Those are gigantic caps!!!! :shock: :shock: :shock:
Post by BrianT » Thu Aug 13, 2015 5:57 am
Snoop65 wrote:Wow!!!! Those are gigantic caps!!!! :shock: :shock: :shock:
Hey you 2 guys, lets not have a pissing match "WHOS GOT THE BIGGEST CAPS" on the main board :D :D :D
But seriously they are really big caps.
Post by Snoop65 » Thu Aug 13, 2015 7:12 am
I give! He wins!!!! :lol: :lol: :lol:
Miko1971
Post by Miko1971 » Fri Aug 14, 2015 12:02 am
Do those caps make my board look big?
Well, they are certainly expensive enough! The 6 caps matched to .5% were $1,800....these are the CuTF V-Caps supposedly the best caps in the business!
Post by MRHP » Fri Aug 14, 2015 5:00 pm
Since you are going "all in" I would suggest looking into some Siemens CCa or Telefunken CCa, either one will have a premium holographic sound stage with a very low noise floor. Also in the same category would be Amperex Holland made 7308 D-getter. The best of the best of these tubes were made pre 1960. Somewhere around 1957 to 1959 vintage seems to do well no mater where they are placed.
1959 thru 1962 Mullard 6922 wrinkle glass will run a strong second to any of the above tubes at probably 1/3 the cost.
Snoop can also fill you in on his findings.
If your coming to CF you are welcome to roll my collection if you please.
