Sunfire 400 X 7 Question
Sunfire Home Theater Discussions and Questions
Post by Don » Mon Jul 11, 2011 9:59 am
Question for other 400 X 7 Owners: (mine is 17 inch wide model, which should be same as 19 inch)
With my 400 X 7 in the auto mode, even without signal present, the outer case will always be slightly warm to touch, which I assume is normal. Last night, for the first time, put toggle on back in the down position, which is off. When felt outer case temperature this morning, still slightly warm to touch. Is this normal even with toggle in down (off) position? :-k
Re: Sunfire 400 X 7 Question
Post by TNRabbit » Mon Jul 11, 2011 10:41 am
It's always warm.
Mine varies from @ 85 degrees when off to approximately 134 degrees (max) when I've pounded the hell out of it for a couple of hours....
Post by thuffman03 » Mon Jul 11, 2011 10:43 am
Sunfires will be warm to the touch. Never should they be hot.
Post by TNRabbit » Mon Jul 11, 2011 10:46 am
thuffman03 wrote:Sunfires will be warm to the touch. Never should they be hot.
Define "hot"~ 8)
Post by Chauss » Mon Jul 11, 2011 12:01 pm
Define "hot"~ 8)
If it is the one he just got.....may-be leaning towards HOT! :lol: :lol: :lol:
The definition of hot.
Post by treitz3 » Mon Jul 11, 2011 3:53 pm
TNRabbit wrote:Define "hot"~ 8)
When you drop trou and cop a squat on the amp. If it burns your boys? It's hot.
Re: The definition of hot.
Post by Chauss » Mon Jul 11, 2011 7:32 pm
#-o .....please remind me to never buy a used amp from you! :lol:
Post by frenchguy » Tue Jul 12, 2011 3:21 am
never thought of checking my amps temp that way!!! LMAO
Post by Scarabeo » Tue Jul 12, 2011 5:12 am
frenchguy wrote:never thought of checking my amps temp that way!!! LMAO
Me too :-& :-s :shock:
Bob Carver Cherry 180's
Sunfire Classic Tube Pre
Jolida JD100 Tube CD Player
Sunfire 3C used as pair
12" Sunfire Sub
Silver coated copper Wires.
Kings Chair of the Gods..
Return to “Sunfire Home (Theater)”
