HDMI cable lengths
Sunfire Home Theater Discussions and Questions
HDMI cable lengths
Post by tinpan » Sat Jan 21, 2012 5:41 pm
Anyone know if there are limitations on HDMI cable lengths? Might want to do a 25' run
Thanks
Re: HDMI cable lenths
Post by treitz3 » Sat Jan 21, 2012 6:35 pm
Tinpan, a 25' length will work fine without having to have a repeater or signal booster. The only thing I would think might be an issue would be the timing of the signal. Depending on how things will be hooked up for your system, the dialog on the TV might not match up perfectly with the sound. I experienced this with a 100' running the audio signal only from HDMI out to a coaxial line for the run in wall, then to a coaxial to RCA into a receiver. The millisecond(s) with delay in sound from the video didn't quite sync up. It was like watching the age old Kung-Fu movies where the audio didn't sync up with the video.
I wouldn't imagine that it would be too terribly noticeable with a 25' run but I thought I might just throw it out there. Obviously, the shortest length possible would be preferred. You might want to check and see if your components have any type of synchronization adjustments. Some manufactures do offer this capability for situations just like yours.
Re: HDMI cable lengths
Post by tinpan » Sun Jan 22, 2012 8:10 am
Thanks Tom,
I guess I can always try it and if I don't like it move it back. I am just trying to think of a way to unclutter one wall. Five speakers, two subs and 2 audio racks make it very crowded. If I can move the audio racks it may give the speakers a little room to breathe,
Not that it sounds bad, but instead of relaxing and listening to the music or watching tv, I find myself staring at the wall thinking " Hmm what if..."
Return to “Sunfire Home (Theater)”
