Page 1 of 1
Got a C-11 or H-9AV? Bring it to CF!
Posted: Tue Aug 07, 2018 3:26 pm
by UncleMeat
To all attendees of this year's Carverfest:
If you have a C-11 or an H-9AV; if you bring it to CF '18 I will show you how to update the Precognition Matrix function so that it works correctly. I have made a modification to mine that corrects a circuitry design flaw which makes the L/R channels switch sides. I suspect that the circuit error also causes some loss of output signal on one channel also (errors causing signal cancellation downstream).
Here is some background information:
https://thecarversite.com/index.php?/to ... ent=177821
https://carverstereoforum.com/forums/to ... sal-fixed/
Depending on interest, I could either help you work on your C-11 or have a workshop event one afternoon/evening at Treehouse A or maybe one of the bigger cabins.
-Russ
