It is currently Sun May 19, 2013 10:36 am
Non-Bob Carver
Re: Non-Bob Carver
Anybody want to add and/or correct?
Re: Non-Bob Carver
Unless the AL-IIIs you have are the "Plus" model.... (no pots on the back)
Re: Non-Bob Carver
Re: Non-Bob Carver
Re: Non-Bob Carver
Re: Non-Bob Carver
Re: Non-Bob Carver
Re: Non-Bob Carver
BillD wrote:Actually, some of the stuff made in Japan had the best layouts. The M-500(t) for instance is super easy to work on 'cause it's laid out so well. The Japanese are absolute masters of packaging.
as it turns out, he had a guy that worked for him that would take the designs that bob and his staff would work out, and his guy would hop on a plane to japan to have them made in a batch that he would return with for testing and so forth. at the time, bob said that the japan factory did top notch work. this was the explanation given to me when i asked if there were any tfm35's made in the usa, as all the one's i have are made in japan. so the 35's are his layout put together by someone else. so he said no, all were in japan with the story above.
Return to Carver Corp. Gone Forever
