It is currently Sat May 25, 2013 10:05 am
Now What?
Post Wed Mar 22, 2006 7:41 pm
One thread up.
Chuck_K
Post Wed Mar 22, 2006 9:20 pm
imo they don't want to fix it.
Post Thu Mar 23, 2006 5:42 pm
elecdik
Post Fri Mar 31, 2006 7:53 pm
Carver Repair in Ontario
Hey Dave.
I have been talking to Ontario Audio Video. Their number is: 1 (905) 791-2020. Ask for Rick. I think he is the head technician.
Good luck.
Dick
Post Sat Apr 01, 2006 12:44 am
kbce
Post Mon Jun 05, 2006 8:34 pm
Roland @ Hi Tec Audio
503 618 7605
He is ~OUR~ last Bastion of Hope.......
Yes..its Oregon.
Owned Carver worked 4 Bob B4 2nd Lynnwood Location. 2-4.0ts 1-1.0t CT-17 PM175 spare C-9 PCA & C-101 'Yamaha AVC50=1/2tape restoration' ~SLab "SL1010" DUAL 10" Sub 180' crossed @ 110~ Need another 1.0t.....{;^(... someday...
Post Sat Sep 16, 2006 12:20 pm
Achtung!!
kloneman1
Post Thu Jun 26, 2008 11:12 pm
Re: Now What?
farkerman wrote:I just found out that my M500T cannot be repaired due to unavailability of components. I live close to Toronto, Ont. I had brought it in to a local stereo repair shop about 10 years ago and they fixed it then. It went boom again, but now they say they can't get the parts.
Anybody know where I can send it?
Thanks
I wonder when Sunfire owners like me will be in this same predicament, only worse, because there is no tech data on the outside regarding Sunfire equipment, as there is for Carver equipment.
Kloneman
Post Thu Jun 26, 2008 11:32 pm
Re: Now What?
Are you kidding.... at $600 a pop, they will fix them forever !!!
1 tek working on 1 unit for 8 hours... ain't no where clost to $600
They will make more profit off a repair, than selling a new amp !!!
Post Fri Jun 27, 2008 11:38 am
Re: Now What?
Tell me how it went "boom". If it went "boom" in a particular way (wide open triac fried the field coil), your technician is correct. Parts are unobtanium. Otherwise, most parts are available or suitable substitutes can be found. I think the best thing to do is to find out from your tech why he says it is unfixable (i.e., which part), and then call Roland.
Post Fri Jun 27, 2008 12:16 pm
Re: Now What?
The ONLY thing I have heard Rolland can't fix, is the Lightstar Preamp, and a couple of the prototype runs made at the end of Carver.... Your repair guy is full of shit... "HE" can't fix it... He probably needs parts, and Rolland won't sell parts.
Post Fri Jun 27, 2008 2:58 pm
Re: Now What?
I thought that only the Magnetic Field Coil and filter capacitors were unavailable but that there was a workaround for the filter caps by piggybacking 2 together to get the value needed. Also, if this unit is in Canada, then Anatech in Georgetown knows how to fix these beasts and is very close to Toronto.
Post Fri Jun 27, 2008 3:03 pm
Re: Now What?
I had no problem getting electrolytic caps for my M-500, and they use all the same ones as the "T"
RichP714
*** !!! BANNED !!! ***
Post Fri Jun 27, 2008 3:52 pm
Re: Now What?
OBI56 wrote:I thought that only the Magnetic Field Coil and filter capacitors were unavailable but that there was a workaround for the filter caps by piggybacking 2 together to get the value needed. Also, if this unit is in Canada, then Anatech in Georgetown knows how to fix these beasts and is very close to Toronto.
I think the OP was from 1996? The M-1.5t is the unit that had dual caps; they switched to separate caps and a mounting block when the dual caps became unavailable
Return to Carver Corp. Gone Forever
