It is currently Wed May 22, 2013 4:09 pm
Sunfire Subwoofer?
Dreamer
Post Wed Sep 05, 2007 10:11 pm
Sunfire Subwoofer?
Is anyone planning to bring a Sunfire subwoofer to the Fest?
Thanks,
--Richard
Post Fri Sep 07, 2007 7:58 pm
Not that I know of. As far as I know, the only sub that will be there is a Polk Audio PSW1000.
Post Fri Sep 07, 2007 8:29 pm
I'd like to hear one if one of y'all want to bring one.....hint, hint
Dreamer
Post Fri Sep 07, 2007 11:12 pm
I wish I had one to bring, and I have a line on a brand-new Super Junior, but even if I ordered it today, it wouldn't be here for 7-10 days, which is AFTER the event...
--Richard
Post Sat Sep 08, 2007 8:39 pm
Bitch of it is my Darkstar won't be finished until after the 'Fest either. I have a Sunfire sub driver too. I just haven't built the enclosure yet. Anyone got a line on one of those Carver speaker sets they produced right before the bankruptcy? IIRC they included either a 300watt or 500watt lightstar amplifier in the sub.........hmmmm.
londonbarn
Cyber Hell Member
Post Tue Sep 11, 2007 5:20 pm
You got it Magnaryder........"One of the hottest markets in home theater is the coveted subwoofer, and Carver’s new Darkstar, although not small in the absolute sense, does use dual 15" drivers, which makes the cabinet small in the relative sense (using dual drivers in this configuration allows the designer to get the best from them in a smaller enclosure). It is shaped like a trapezoid, and has a neat blue illuminated logo on the front. The Darkstar is powered by a 1,500 watt amplifier using the Lightstar technology. At $1,495, this should be a big seller.".........I would imagine the Lightstar technology part is the Tracking Downconverter.........
Post Mon Sep 17, 2007 10:02 pm
I'm reconstructing the trapazoidal shaped enclosure and using the 1000 watt plate amp from PE to power my single Darkstar woofer. good idea of the backlit logo.....Toymaker, wanna make that while you build the clear tops for my Lightstar duo?
Return to CARVERFEST 07'
