CarverFest Streeming Video
"The Sequel" Sep 10-15
Live feed Q&A on the pooter...........
Post by treitz3 » Sun Sep 07, 2008 12:05 pm
If someone wants to volunteer to man the computer, sure. There will be a few laptops around. I'm sure someone might step up to the plate, but it ain't gonna be me. We'll ask for a volunteer at the Thursday meeting. Keep your fingers crossed.
Re: CarverFest Streeming Video
Post by BillD » Sun Sep 07, 2008 2:08 pm
Well, I still can't get it to work. I had it working when you first posted this, but now it just doesn't work.
I logged in as Carver7 with password = 7 or audio, and no luck. Nothing has changed on my end. Using IE7 with XP SP3.
garcianc
Post by garcianc » Sun Sep 07, 2008 2:38 pm
Working well here using IE running on Linux. No luck with Firefox.
One of the posts mentioned that you might be using DynDNS to setup a dynamic domain name?
I wasn't sure if that's what you meant. If so, what will be the url?
If not, and not to insult anyone's intelligence, two comments:
1. the IP address will be different so, once you are setup at the Fest you will need to publish directions.
2. you may not be able to receive incoming connections to port 2000 (or any other port) if you will be reaching the internet downstream of somebody else's router/firewall (i.e. the cabins' wireless LAN).
But, since you guys will "own" the cabins for the weekend, they may let you punch a hole thru their firewall. Good luck.
I don't mean to be negative, I really, really hope this works since it is the only way that I will get to participate this time. :(
Thanks for the hard work ToyMaker. You guys have fun and don't mess with Sasquatch. We want everyone back in one piece.
Post by Toy Maker » Sun Sep 07, 2008 6:46 pm
garcianc wrote:Working well here using IE running on Linux. No luck with Firefox.
Thanks for the advice... I got that all coverd, I already have the passwords for the routers in the cabins \:D/
Like you said, the IP address will change once I get there and set everything up. I will update the links here, and post the new IP.
BillD.......
It's not Carver1 anymore... it's just "1"
I dropped the Carver, and am only using the numbers 1-20, as the username, and the same # as the password.
Return to “CARVERFEST 08'”
