DIY power cords and speaker wire
Custom Equipment Mods.
Re: DIY power cords and speaker wire
Post by Magnaryder » Fri Oct 15, 2010 8:50 am
F1nut wrote:Ray and Roy.....Roy and Ray.....
What brand/model of power conditioner?
Jesse.... it was an inexpensive unit from AR. But, it has a huge warrantee policy to repair/replace anything that gets damaged by electrical storm or surge. I use it at home to cover everything EXCEPT my Lightstar gear. They have power conditioning built in.
Post by elgrau » Fri Oct 15, 2010 11:15 am
"Hot damn, I use the same "acid test" and the whole issue is far from a waste of time, Ed."
By "whole issue" F1, I meant the part about caring what anyone else thinks about one's choice of tweaks (this thread issue degradation)....not the "whole issue" of achieving better sound. I agree, THAT issue is not a waste of time.
Post by engtaz » Fri Oct 15, 2010 11:46 am
PT 2400 has removable PS cords.
Post by F1nut » Fri Oct 15, 2010 1:09 pm
TNRabbit wrote: FYI to you both: I've found this "acid test" is sometimes nothing more than a recording that has been compressed. When you lose the dynamics, the soft whisper in your ear is almost the same level as the drummer pounding on the snare. So be careful about using previously unheard things in a song to determine that you've reached a new level in sonic ecstasy. I'm not saying this is an absolute, but compression can definitely cause this phenomenon.
Gary, I was referring to gear tweaks, not a new recording.
Make America Great Again
Post by F1nut » Fri Oct 15, 2010 1:17 pm
Ok, thanks. When purchasing surge/power conditioners one should always check that it has unrestricted high current abilities. From the noted results using yours, it definitely does not.
Post by F1nut » Fri Oct 15, 2010 1:19 pm
elgrau wrote:"Hot damn, I use the same "acid test" and the whole issue is far from a waste of time, Ed."
I gotcha now Ed, thanks.
Post by elgrau » Fri Oct 15, 2010 1:43 pm
"Gary, I was referring to gear tweaks, not a new recording."
what he said, too...(once I own the CD, I'm not likely to replace it with anything else...being the "cheapskate" that my wife and kids know me to be...the damn deadbeats... :lol: )
Post by F1nut » Fri Oct 15, 2010 1:57 pm
elgrau wrote:
what he said, too
I was sure that is what you meant too, but didn't want to speak for you.
mcnishra
Post by mcnishra » Tue Dec 11, 2012 7:46 pm
Dr W. or anyone please help! I found some garnet shot that is used just like steel shot. This stuff was given to me free (Cheaper then buying steel shot) and I wanted to know if I could use this instead of steel shot. Please let me know. I can't find anything on the internet that advises otherwise :-k
Dr. W
Post by Dr. W » Wed Dec 12, 2012 1:21 am
micnishra,
I don't believe garnet will have nearly enough iron content to create the electromagnetic shielding that steel shot does.
But the shot will probably create some damping effect. Since it was free give it a try. Make two identical cords, one with garnet shot, the other with steel shot.
My guess is the one with steel shot will sound substantially better.
Dr. W
Bruce A Weiland, my system here -->> http://forum.audiogon.com/cgi-bin/fr.pl ... ce_weiland
mcnishra
Post by mcnishra » Wed Dec 12, 2012 10:22 am
I appreciate the info... That makes a lot of sense. I found a vendor on eBay that sells steel shot but the size is s170 (0.5mm). Is that too big? I was looking at your recipe for the cables you made and could not figure out which size you used. Can you please advise? Thanks!
Dr. W
Post by Dr. W » Wed Dec 12, 2012 10:57 am
I will have to check. I will get back to you.
Dr. W
Post by Dr. W » Wed Dec 12, 2012 11:09 am
There was only a felt tip pin marking on the box I was given; S-110.
A quick search returned this
S110 Carbon Steel Shot
SAE Size No. SAE J444
Shot Tolerances Screen Opening* in - mm
S110 All Pass No. 30 Screen .0234 - 0.600
10% Max on No. 35 Screen .0197 - 0.500
80% Min on No. 50 Screen .0117 - 0.300
90% Min on No. 80 Screen .0070 - 0.180
Based on the above, you should be OK. Just eyeballing mine they look like 1/3 to 1/4 millimeter, but you can see the specs above.
Bruce
mcnishra
Post by mcnishra » Wed Dec 12, 2012 12:14 pm
Thanks a lot Bruce! I'll give it a try and hope for the best. :D
Return to “!!! MODS !!!”
