PAIA tube buffer
Custom Equipment Mods.
PAIA tube buffer
Post by mbskeam » Thu Jun 24, 2010 11:54 pm
stealing the guts out of one and makin my own box....
tube head....
made a stainless box today.....
my next project..... \:D/ \:D/ \:D/ \:D/
got my grandfathers stash of tubes, there are 3 more boxes full
Re: PAIA tube buffer
Post by engtaz » Fri Jun 25, 2010 3:40 am
Cool project.
Post by mbskeam » Sat Jul 10, 2010 7:23 pm
made up some brass sleeves.....
waiting on the power supply, and need 12Ax7 tubes
Post by TNRabbit » Sun Jul 11, 2010 7:37 am
Damn, Mike; you do good work! =D>
Post by mbskeam » Mon Aug 02, 2010 9:56 pm
it's done kinda....
now to get the left channel to work, think the left op amp is toast. a .90cent part.... :shock: :shock: :shock:
Post by engtaz » Tue Aug 03, 2010 4:12 am
Nice work. Congrats.
Post by TNRabbit » Tue Aug 03, 2010 5:21 am
Looks good, Mike!
Are those blue LEDs around the RCA inputs?
Post by kingman » Tue Aug 03, 2010 5:46 am
It looks super!!! =D> =D> =D>
Post by helicopterpilotdoug » Tue Aug 03, 2010 5:49 am
Beautiful work! Love the glow of those tubes. :)
peck555
Post by peck555 » Tue Aug 03, 2010 12:09 pm
Nice job, good luck with the left channel. =D>
brit01
Post by brit01 » Mon Aug 30, 2010 11:55 am
What are you using this for?
Do you have a schematic?
12AX7 is not the best choice for a buffer due to it's non-linearity. Better for guitar amps (unless that's what you're doing 8) .)
What specs do you have? B+? PSU design? AC on heaters?
Resistor cathode bias?
I've made some with 6N6P, 6N1P and 5687 also with CCS (cascode DN2540) and led bias.
What pots/caps/resistors are you using? The alps are very good.
Post by mbskeam » Mon Aug 30, 2010 2:48 pm
no, it has none of what you asked......
http://www.paia.com/manuals/docs/9305-t ... ematic.pdf
it is a very simple thing, the PS is a wall wart
got the right ch to sound clear but the left is still bad.
ordered a 2 new op amps, but what I did was order the wrong ones...... ](*,) ](*,) ](*,)
lost a whole 2.00 there.... :-$
testing this using my tuner as a source, my cd has tube output so I want put it there....
just a toy to play with and learn how much I really dont know..... 8-[ 8-[ :D
just got an oscilloscope from my dad, forgot he had gotten this from an old man down the street for 25.00 bucks....
now a new toy to play with..... \:D/ \:D/ \:D/
brit01
Post by brit01 » Mon Aug 30, 2010 5:56 pm
doesn't look simple to me. [-(
I can give you a design that is far simpler and out perform this.
Are you looking for a buffer, no gain, just as a passive tube sound between a source and amp?
Buffer, such as cathode followers can degrage the sound if not done properly but it can still be done very easily.
The less stuff in the signal path the better.
brit01
Post by brit01 » Tue Aug 31, 2010 5:37 am
Try this out with a 6N6P (or something similar, changing bias resistors as necessary):
Also you could put a CCS on the plate to keep things stable.
LED's are also a great alternative to cathode resistors and work well with a CCS on the plate.
This is a Cathode follower with bootstrap. See how few components it has? Use a good quality Alps pot (around 10 USD from mouser). AC on the heaters. That's about it.
Maybe some hexfreds on the power supply.
Use Duncan PSUII to design your power supply and get your desired B+ with lowest ripple: http://www.duncanamps.com/psud2/
cf proto.jpg (30.04 KiB) Viewed 2753 times
DN2540 cascode CCS.gif (2.63 KiB) Viewed 2753 times
Return to “!!! MODS !!!”
