al-III 48" ribbon x-overs with poly caps
Custom Equipment Mods.
Post by angelod307 » Wed Oct 06, 2010 2:54 am
nice. real nice. more easy going and effortless. and that is only with several hours play time. not bad for $100 worth of dayton 75uf caps. real nice i tell you.
Re: al-III 48" ribbon x-overs with poly caps
Post by BillD » Wed Oct 06, 2010 11:03 am
Glad you like them. I'm bypassing the high pass and low pass filters (that have electrolytics in them) and going with an active crossover. Still need to replace the one 76µF electrolytic cap in the notch filter, and have a pair of polyethylene caps on order.
Post by mbskeam » Wed Oct 06, 2010 5:25 pm
pics please and a diagram would be nice also...... [-o<
Post by BillD » Wed Oct 06, 2010 6:22 pm
OK, I did take the time to map the AL-III Plus crossover. First a picture of the original.
Now, mapping the schematic, I came up with this (matching the components labelled on my picture).
And, here's how I plan to change the crossover (simply eliminating the high and low pass filters, and replacing C4 with a polyethylene cap). Of course I'll be using an external active crossover. I'm going for a cross someplace between 150Hz and 200Hz.
AL-III Plus.jpg (31.68 KiB) Viewed 1197 times
The cap replacement came in today, so here's a look at the size difference.
I measured the caps, and they are both above 75µF. One is about 75½ and one is about 76½. I'll measure C4 when I get it out of there, but I imagine it will be anywhere from 70 to 85µF. Electrolytics, even the best of them, are seldom close to their rating.
Post by mbskeam » Wed Oct 06, 2010 8:23 pm
thanks.... \:D/ \:D/ \:D/ \:D/ \:D/ \:D/
Return to “!!! MODS !!!”
