need parts for a carver C-1
zobsky
Post by zobsky » Mon Dec 29, 2003 12:30 pm
Hi,
at low listening levels, the left and right channel volume levels on my setup are somewhat different. I have narrowed the fault down to my carver C-1 preamp. this problem disappears somewhat at higher levels but the balanece is never quite equal.
i'm guessing that the preamp volume potentionemter is going out on me.
while i'm going to shoot some more ciag de-oxit down the the volume pot in the near future, i fear that maybe the pot itself is bad. ... or could it be the opamps itself? doees the headphone output also use the same signal path as the pre-amp out? any troubleshooting hints?
in case the pot IS the issue, where can i obtain a replacement part and what is it going to cost me just for the part (if anyone has an idea), .. and while i'm at it, is there a superior replacement part i can use in place of the original pot.
thanks, vin
CARVERSTEVE
C-1
Post by CARVERSTEVE » Wed Jan 28, 2004 4:10 pm
CALL 360-862-0199 FOR ANY CARVER PARTS OR SERVICE
zobsky
Post by zobsky » Thu Jan 29, 2004 9:55 am
thanks, ..
CARVERSTEVE
CARVER C-1
Post by CARVERSTEVE » Thu Jan 29, 2004 12:41 pm
IF YOU CALL 360-862-0199 YOU CAN TALK TO CARVER TECH FREE OF CHARGE. RITA WILL BE ABLE TO ANSWER ANY QUESTION YOU MIGHT HAVE.
THANKS CARVER STEVE
