CT-17 Single Channel Problem
I'm wondering if anybody can be any help with my CT-17 Pre-Amp. If I'm in the wrong section, please point the way.
Anyways, the problem is:
I get most of my audio through one channel. The balance knob is adjusted at center so no problem with that. There is no problem with power amp as I have tested with two of them. When I switch the pre-amp to hologram, there is some noise present on the other speaker. The audio will switch to the other speaker when I switch the audio wires. Also, the audio coming over the regular pre-amp channels sounds like I'm getting some distortion. When I switch to remote output, the sound is great, but I have no direct control over it from the front panel switches. I'm assuming that this is the way remote output works so no problem there.
If anybody that can help has suggestions, please let me know. If more information is needed, please let me know. Thanks.
