TFM-22 problem
TFM-22 problem
Post by kingman » Wed Oct 21, 2009 4:20 pm
Wondering if any of you can diagnose this problem. Left channel works good, right has static. when volumn is turned up past 9 0'clock position, amp clicks, and shuts down completely. Turn volumn down, resets itself and starts again. Anything a dummy like me can replace with help or is this a Rita repair?
Re: TFM-22 problem
Post by thuffman03 » Thu Oct 22, 2009 9:03 am
My TFM 55 had the same issue. It is going into protection mode and the output transisters need replaced/repaired.
Re: TFM-22 problem
Post by kingman » Fri Oct 23, 2009 9:14 am
thuffman03 wrote:My TFM 55 had the same issue. It is going into protection mode and the output transisters need replaced/repaired.
Thanks Tom...I was also wondering if it couldn't be the filter capacitors because of the static???
Re: TFM-22 problem
Post by beemers417 » Fri Oct 23, 2009 4:42 pm
Replace the caps and go from there. I think I have transistors here for the 22 if you need some.
Re: TFM-22 problem
Post by kingman » Fri Oct 23, 2009 5:22 pm
You know where to get the caps Tom???
Re: TFM-22 problem
Post by BillD » Fri Oct 23, 2009 5:27 pm
I get caps at Digi-Key. Here's a TFM-25 list I made up for jazzman53.
Code: Select all
Carver Number  Qty Description   Manufacturer #  Digikey # Spacing TFM-25 Component       Cost   Total  Comment
NS-16TW 220M    4  22µF 16v      UPW1C220MDD    493-1769-ND   2    C401-C402, C405-C406   $0.34   $1.36
NS-50TW 4R7M    5  4.7µF 50v     EEU-EB1H4R7S   P13465-ND     2    C409-C410, C205-C206   $0.11   $0.55
NS-16TW 101M    4  100µf 16v     UTT1C101MDD    493-3271-ND        C411-C414              $0.47   $1.88
NS-25TW 470M    8  47µF 25v      EEU-EB1E470    P12125-ND     2    C415-C416, C307-C308   $0.17   $1.22 Buy 10
NS-25TW 100M    1  10µF 25v      UPW1E100MDD    493-1809-ND   2    C451                   $0.34   $0.34
NS100TW 1R0M    4  1µF 100v      UPW2A010MDD    493-1962-ND   2    C211-C214              $0.33   $1.32
NS-25TW 220M    1  22µF 25v      UPW1E220MDD    493-1811-ND   2    C309                   $0.32   $0.32
NS-25TW 330M    1  33µF 25v      UPW1E330MDD    493-1814-ND   2    C310                   $0.32   $0.32
NS-35TW 471M-KF 1  470µF 35v     UHE1V471MPD    493-1582-ND   5    C-509                  $0.66   $0.66
BC00 103NN60GH  2  10000µF 100v  ECE-T2AP103EA  P10038-ND    22.5  C501-C502             $11.96  $23.92 4-prong snap in
BC63 332N240HC  2  3300µF 63v    ECO-S1JA332BA  P7481-ND      10   C503-C504              $4.79   $9.58 snap in
BC35 682M240HC  2  6800µF 35 v   ECO-S1VA682BA  P6660-ND      10   C505-C506              $4.11   $8.22 snap in
NS-50TW 1R0M    1  1µF 50v       UPW1H010MDD    493-1886-ND   2    C510                   $0.30   $0.30
S76R3TW 221M-RT 2  220µF 6.3v    UPW0J221MED    493-1699-ND  2.5   C109-C110              $0.36   $0.72
        Total   $50.71
Re: TFM-22 problem
Post by thuffman03 » Fri Oct 23, 2009 5:30 pm
That is a good list to have. Thanks Bill!
Re: TFM-22 problem
Post by BillD » Fri Oct 23, 2009 5:54 pm
Well, transferring from Excel to ASCII text lost a couple of lines.
For the 4.7µF 50v caps where it says quantity 5, but only 4 are listed, the fifth one is C311. Where it says Buy 10, but only 4 caps are listed, the other 4 are C507-C508 and C511-C512. The caps were 17¢ apiece, but if you order 10, its $1.22 (.17 x 8 = 1.36).
Re: TFM-22 problem
Post by beemers417 » Fri Oct 23, 2009 6:43 pm
Digikey and Mouser are the two best. I see the post from BillD has the digikey numbers already listed. That is spiffy =D> =D> =D> I will be printing a copy of that. \:D/ \:D/
Re: TFM-22 problem
Post by BillD » Fri Oct 23, 2009 6:45 pm
I fixed my list.
Code: Select all
        C311
        C507-C508, C511-C512
        Total   $50.71
Re: TFM-22 problem
Post by kingman » Mon Oct 26, 2009 6:16 am
Thanks to all for the replies and especially to BillD for the great parts list!!! =D> \:D/ =D>
Jazzman53
Re: TFM-22 problem
Post by Jazzman53 » Wed Oct 28, 2009 5:12 pm
Hi Kingman
I just capped a TFM-25 which I believe is the same amp with different meters. I used BillD's parts list and he and RichP helped me out on the project. I posted a write-up with pics on "that other site": http://thecarversite.com/yetanotherforu ... #post17768
Good luck with it !
