TFM-55 meter lights
rocketman50
TFM-55 meter lights
Post by rocketman50 » Fri Nov 20, 2009 4:46 pm
Got the TFM-55 hooked up...works great and what a diff from the TFM-25. But I do like the 25s meter light dimmer, which the 55 lacks. Anyone have any idea how the light in the 55 might be dimmed a little.?
TFM-75, TFM-55, TFM-25, (2) TFM-15CB, Integra 9.8 processor
Re: TFM-55 meter lights
Post by kingman » Fri Nov 20, 2009 4:51 pm
Both of my 55's the regular and the x have the range and/or dimmer/light button on the front? If you've got a 55, it has the same. Just push the light button on the faceplate of the X or the dimmer button on the regular.
rocketman50
Post by rocketman50 » Fri Nov 20, 2009 5:57 pm
"dimmed a little.?" from my post...
Don't want to shut off...but dim. On the 55 they are really bright. Maybe lower watt bulbs.?? Don't know the answer...
Post by thuffman03 » Fri Nov 20, 2009 6:45 pm
On my 55 it dims it some but not as much as the 25 allows you. I think the 25 will allow you to turn almost all the way off.
Post by kingman » Fri Nov 20, 2009 7:37 pm
thuffman03 wrote:On my 55 it dims it some but not as much as the 25 allows you. I think the 25 will allow you to turn almost all the way off.
I think Thuffman is correct...my friend has a 25 and as I remembeer it had a potentiometer brightness adjustment. I have both my 55's on the lower setting...how low do you want????
Post by thuffman03 » Fri Nov 20, 2009 8:21 pm
If they are new bulbs they can be a bit bright. Over time they will fade. Though if you are good with electronics you could put a on the lights.
stevewithrow
Post by stevewithrow » Sat Nov 21, 2009 1:51 am
rocketman50 wrote:"dimmed a little.?" from my post...
Add a set of ALS,s...that should dim them....
rocketman50
Post by rocketman50 » Sun Nov 22, 2009 8:59 pm
Sure...Then why not sell the excess back to the power co...??? :)
