Carver TL 3100 R602 Resistor value?
MycarverTFM35
Post by MycarverTFM35 » Thu Jan 28, 2010 10:45 pm
Hoping someone can help me find the resistor value on a TL 3100 CD player circuit board. The resistor is burnt beyond recognition cannot tell what value it is. The location on the board is R602. I tried finding a schematic online withought any luck .. any help would be appreciated..
Re: Carver TL 3100 R602 Resistor value?
Post by Eddie » Fri Jan 29, 2010 6:45 pm
R602 part # =KA16ST102J
KA=carbon type
16S= 1/6 wattage
T=?
102= 1k value
J= + or - 5% tolerance
This is what I came up with!!!!!
Post by BillD » Fri Jan 29, 2010 6:53 pm
Eddie's right, but I've never seen a 1/6 W 1kΩ resistor. Reisstors usually come in ¼, ½ or 1W varieties.
MycarverTFM35
Post by MycarverTFM35 » Fri Jan 29, 2010 9:11 pm
Eddie wrote:R602 part # =KA16ST102J
KA=carbon type
16S= 1/6 wattage
T=?
102= 1k value
Thanks very much Eddie for the info, I wasn't sure if i would ever find it. Bill mentioned that the wattage seemed low (1/6 watt) if so, wouldn't it be safer if i use a larger wattage resistor to make sure,? say i use a 1/4 watt or 1/2 watt ?
Thanks again guys:)
Mike
Post by BillD » Sat Jan 30, 2010 12:03 pm
If the resistor is tiny, go with ¼. If it's larger, go with ½W. It won't matter. The 1kΩ is the key.
MycarverTFM35
Post by MycarverTFM35 » Sat Jan 30, 2010 1:42 pm
BillD wrote:If the resistor is tiny, go with ¼. If it's larger, go with ½W. It won't matter. The 1kΩ is the key.
Thanks will do
Take care
Mike
