It is currently Wed May 22, 2013 8:13 pm
TFM-45 Bias,offset,damping adjustment procedure
Post Tue Mar 23, 2010 9:44 pm
Re: TFM-45 Bias,offset,damping adjustment procedure
HOLLY PICTURES BATMAN....LOL
thanks,
but ....
Adjust RP2 on each amp board until you get 1v across the 8ohm load resistor at each output
so do I put the leads on each side of the load resistor?
this is new to me also, so any help, thanks.....
Post Tue Mar 23, 2010 10:37 pm
Yep
gunner64
Post Tue Mar 23, 2010 10:43 pm
Just make sure you're on the same board as the output you're testing.
Yea,I know freaking trainwreck of a post.sorry for that!I tried to make the pics smaller but like I mentioned,I'm more or less not computer friendly,so my efforts to decrease the size were futile.Again accept my apologies,for I've made a huge mess!But hey, if you take it down to 50% or less you can see were the adjustments are in the amp.Hey I tried.........And any suggestions you can give me as to how I can post normal size photos without looking like an idiot would be appreciated.Not that I won't look like an idiot,just an idiot with normal sized pics.
Robert
Post Wed Mar 24, 2010 1:14 am
try this, very easy to load and use
works real nice.....
http://bluefive.pair.com/pixresizer.htm
this is a small stand alone program that you open when needed, and close when done, unlike some of the crap that likes to run all the time and worms it way into places they dont need to be.....
Post Wed Mar 24, 2010 12:46 pm
That (previous) program will most likely work fine for what you need, Gunner; but if not, I bought ($29 or such) a commercial one called Jpegsizer (google it if interested). Works great!
gunner64
Post Wed Mar 24, 2010 1:15 pm
Thanks guys,I'll give the first one a try.I couldn't do any worse,thats for sure.
Robert
gary_wong5
Post Wed Apr 21, 2010 10:29 pm
gunner64 wrote: 3.Set Damping.Attach an 8 ohm dummy load to both outputs.I used 2, 20w 8 ohm resistors from radio shack.The amp will be only outputting 1v,so the 20watters will be o.k. for this adjustment.Insert a 2khz 36mv signal to the inputs of the amplifier.Use the signal generator from Higherfi.com and your preamp to get the proper signal if you don't have a dedicated signal generator.Once I got a 2khz signal I adjusted the volume on the preamp for 36mv at the pre-outs.Adjust RP2 on each amp board until you get 1v across the 8ohm load resistor at each output.Keep in mind your pots here may look dif. than mine,as mine have been replaced per damping drift fix at back of service manual.]
Hi gunner64, I have bought digital multitester. Please put some pictures on how you feed 2kHz signal. How is signal generator looks like? :?
gunner64
Post Fri Apr 23, 2010 7:30 pm
you need to go to the higherfi.com and download the test bench.one of the options on the test bench is a signal generator.just follow the instructions I posted earlier(with pics)you'll need a y cable with l/r rca plugs on one end and a corresponding jack from your computers audio out on the other.I used the headphone jack on my laptop.
gary_wong5
Post Sun Apr 25, 2010 10:55 pm
It is no way to get 20W8ohm resistor locally unless get from internet. There are two nearest spec., viz. 10W8.2ohm and 25W10ohm. Can I use or modified to use either of these?
gary_wong5
Post Wed May 12, 2010 8:14 am
gary_wong5 wrote:It is no way to get 20W8ohm resistor locally unless get from internet. There are two nearest spec., viz. 10W8.2ohm and 25W10ohm. Can I use or modified to use either of these?
There is no shipment to Malaysia for 20W8ohm from both Parts Express or Amazon, can anyone here advise where to get the right 20W8ohm resistors? Thanks!
Post Wed May 12, 2010 12:05 pm
I did a little look at Mouser and Digi-Key. Here's the cheapest I could find (I went up to 50 Watts because they are cheaper than 20W).
http://www.mouser.com/ProductDetail/Arcol/HS50-8R0-1/?qs=sGAEpiMZZMuQ5%2fsBR7SoApeYXA2q7aZRcfiEEp0lbLA%3d
Post Wed May 12, 2010 3:47 pm
this weekend as I was digging into my wire box, I find a set of resistors.
I set these out thinking I may need these....... :-s
then I read that you cant find the resitors you need, so I look and they are the size you need.
you can borrow them if ya need to, let me know.......
got these years ago at an autoparts store.....napa I think
gary_wong5
Post Fri May 14, 2010 11:26 am
BillD wrote:I did a little look at Mouser and Digi-Key. Here's the cheapest I could find (I went up to 50 Watts because they are cheaper than 20W).
Hi BillD, USD3.26 x 2= USD6.52 plus courier charge USD40.00, total USD46.52 sounds too heavy to buy #-o
BigBadWally
Post Fri May 21, 2010 11:45 pm
Thanks much for the descriptions and the pics. I'll be recapping and adjusting my TFM-45 soon and this info will definitely come in handy. I have a question, though. Why use such high wattage load resistors? You mentioned that while adjusting the damping the amp will output 1V. If this is the case, since power is equal to voltage squared divided by the resistance, the the power dissipated is (1 * 1) / 8 = 1/8th watt. Double that to 1/4 watt for some margin and you're good to go. Mouser sells an 8 ohm 1/4 watt metal film resistor (1% tolerance) for around a buck. Or am I missing something?
Post Sat May 22, 2010 12:38 am
It's a VERY sensitive adjustment and if you adjust it too much in the "wrong" direction (evidently) the voltage can go up a lot. I did this with mine and the resistors heated up REAL fast (and smelly!).
