It is currently Sat May 18, 2013 9:51 am
TFM 45 Rumbling Noise-Help
crvlvr
Post Thu Mar 25, 2010 1:56 am
As few months ago it would cut out once in a while and make this rumbling "brrp brrp brrp brrp" noise (similar to a V-twin motorcycle idling is the best I can describe it) from the speakers . I would turn it off for a few minutes and turn it back on and it would be ok.
Now, all it makes is that noise. If I leave it long for too long, it blows the fuse. Fuse has been replaced.
I opened it up and noticed that one of the power supply diodes was broken in two. I got a replacement and soldered it on. But, that did not solve the problem.
I'd like to exhaust most simple fix options before I consider sending it to Rita's as that will probably cost me pretty penny with shipping etc.
I have 2 X15CBs that have been working great for the past 16 years and am kind of disappointed with the TFM- 45 :(
Any suggestions?
Thanks in advance.
Post Thu Mar 25, 2010 11:39 am
Re: TFM 45 Rumbling Noise-Help
The TFM-45 is a far different beast than a 15. It is a true magnetic field amp, which means it's taking feedback from the amplifier to adjust the voltage and current delivered by the power supply (simplified). Anyway, I would check all your rectifiers. Some are just 4 big diodes (axial) on the circuit board. Some are 4 SIPS. There might even be a big one bolted to the chassis (a D-34 mount).
Post Thu Mar 25, 2010 11:30 pm
Whenever I get the rumbles I find that a good dump is in order.
Post Thu Mar 25, 2010 11:33 pm
:lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
Post Fri Mar 26, 2010 6:00 am
+1000 on that!! I know exactly what you mean F1nut. :lol:
crvlvr
Post Mon Mar 29, 2010 2:04 am
Thanks BillD. I'll go back and check the rest of the diodes
Denon CD Player , Carver CT-17, 2X Carver TFM-15CB, Carver TFM-45, Infinity SM122
crvlvr
Post Fri Apr 02, 2010 1:46 pm
Good news. Replacing another power diode seems to have fixed the problem!! Yippe Ka Yey! Rumbling has been fixed without having to take a dump. Although, I was going to try that next.Thanks again BillD! :)
