It is currently Wed Jun 19, 2013 4:34 am
tfm-45 lightbulbs
bigerik
Post Sun Mar 28, 2010 11:03 am
tfm-45 lightbulbs
The meter lights in my tfm-45 have blown, and I understand that direct replacements are now challenging to find.
Anyone know where I can get a pair?
Thanks!
TFM-45, M1.0t, C-19, CT-27v - More to come! :)
Post Sun Mar 28, 2010 2:14 pm
Re: tfm-45 lightbulbs
I believe some have found that LED's are a better choice, but you're going to have to research that one.
bigerik
Post Sun Mar 28, 2010 2:20 pm
F1nut wrote:I believe some have found that LED's are a better choice, but you're going to have to research that one.
Would prefer to stay with an incandescent bulb. Just like the colour more.
And research requires work, and I try to do that as little as possible. :)
Post Sun Mar 28, 2010 2:38 pm
And that's why you aren't going to get an answer. We aren't your servants.
Post Sun Mar 28, 2010 4:52 pm
BillD wrote:And that's why you aren't going to get an answer. We aren't your servants.
Post Sun Mar 28, 2010 9:47 pm
Post Sun Mar 28, 2010 9:54 pm
TNRabbit wrote:Tiger Woods
? TIGER WOODS ?
Image[/quote]
bigerik
Post Mon Mar 29, 2010 12:06 am
kingman wrote:http://www.kenselectronics.com/lists/lites.htm...Item 419-Clear
Thanks!
Very much appreciated.
beerbudgetFi
Post Fri Oct 01, 2010 3:42 pm
I have tfm35s (3) tha has been bolwing lamps so I replaced them with super bright LEDs. I wired two in series with 560 ohm 1/2 watt in serires. Never have to replace them again. Not sure about the 45s if they have the same voltage rating. The tfm 35 has 24volt supply to the circuit. The lamps are wired in series so the oprating voltage for each is 12 volts.
3 Carver TFM35X, Sunfire TruSubwoofer, Magnepan 1.5, Magnepan MMG, Paradigm Monitor speakers, Technics SL-D2, Pioneer Turntable PL-518, Sony Playstation3 blu-ray player, Grado SR60 headphones, Onkyo TSR-805 functions as pre-amp, garden variety interconnects but not cheap and a set of ear.
