It is currently Tue May 21, 2013 11:46 pm
110v to 240v conversion for av754 and tfm25
akkoelsch
Post Thu Aug 05, 2010 3:42 am
Hi, I am trying to convert a tfm 25 and an av753 from 110v to 240v. I could use a step down transformer, but the transformers housed within the carvers may have the windings (there's a tfm 25 service manual that lists "voltage conversion" as a topic). Question: Does anyone know of a procedure to do this - or does someone know that internal changes can not be done and that step down transformers have to be used?) Thanks for any insights!
Post Fri Aug 06, 2010 6:53 pm
Re: 110v to 240v conversion for av754 and tfm25
I have notes somewhere around here for the TFM amps. I will start looking. It has been a while since I did a conversion.
akkoelsch
Post Sat Aug 07, 2010 1:17 am
Thanks for looking! I've found the page in the service manual for the tfm25 - the procedure seems simple, I'll give it a shot. Next the AV753 - I have not seen a service manual for it yet, nor have I seen a 220V version of it. Still more research to be done on the AV753.
