It is currently Thu Jun 20, 2013 3:49 am
TFM 35 Voltage at TPs
tgunnd39
Post Fri Sep 03, 2010 6:43 pm
Just a quick question:
What should be the voltage at test points 201/203 & 202/204 on a TFM 35?
Any help is greatly appreciated!
Thanks O:)
Post Fri Sep 03, 2010 8:10 pm
Re: TFM 35 Voltage at TPs
I believe they are like the M-1.0t at 0.5mV
tgunnd39
Post Fri Sep 03, 2010 10:05 pm
Thank you Bill :)
201 was at 6.5mv and 202 was at 4.9 after settling, so thanks again.
Post Sat Sep 04, 2010 11:37 am
Well, you are supposed to set those after turning on the amp from cold and waiting 2 minutes. They will drift higher after the amp continues to warm or be used.
