It is currently Mon May 20, 2013 11:21 pm
...What about the difference in gain volume??? Is this the result of something going bad ???
Zoot Horn wrote:After re-reading your post,, all you may need is a SUT (step up transformer),,I use a cinemag sut with my dynavector phono stage--since I have a lomc cart,,thats all I needed to do--if you find that is the case with you--contact jerryj12,,as he has a nice SUT that he's gonna part with--good luck--let us know what happens--george
Zoot Horn wrote:Wayne-- do you have a phono board ?
What kind/type of cart? MM/MC?
Zoot Horn wrote:Zoot Horn wrote:Wayne-- do you have a phono board ?
Thanks Bruce-- I still don't know if Wayne has a phono board,,I have a "free standing" phono pre,,and I have just recently built a Cinemag SUT,, for/with my LOMC,,and I'll tell you what,,,WOW--much improved using the SUT to the phono pre vs just the phono--I am certainly no expert on Sunfire,but if Wayne does not have the phono board,and IF his pre is capable of accomodating one,,that might be the best way to go--so,,Wayne--you have a phono board in that puppy?
,You know that Bob wanted to hear your speaks with vinyl playing thru them,,lemme' know and we'll get to work.(pair of) SILVER-7 TUBE AMPs
Zoot Horn wrote:OK-- do you know if you pre amp is capable of accomodating a phono board,,like Brians at CF?
If yes,, then I would get in contact with Bob and get one of his "tweaked" boards
If no,, then you are lookig at a "stand alone" phoho pre---so,, then you need to decide,,tubed or solid state,,, then,,your budget-- once you get those answered--I'll get on the clock and find one for you,if you like--ahhh,, your journey is just beginning,,,,,betcha' can't wait to hear some vinyl thru those AL III's eh?,,You know that Bob wanted to hear your speaks with vinyl playing thru them,,lemme' know and we'll get to work.
