It is currently Thu Jun 20, 2013 7:27 am
display lamp spec for TLM-3600?
Dennis47
Post Sun Oct 24, 2010 1:51 pm
Can anyone give me the correct function display lamp
specification for a TLM-3600 10-CD Compact Disc Player?
Thanks....
PL 4000 II / PL 400 II (2) / PL 5100 II / PL 6000 II
PL 7000 II / PL 1000 w/JVD mod (2)
Carver C-1 / C-11 / C-4000t /M-1.0t (MKII opt 002)
M-1.5t (2) / TFM-15 / TFM-22 (2) / TFM-24 (2)
TFM-45 / HR-752 / DPL-33 / TD-1400 / TD-1700
TDR-2400 / TX-12 / DTL-100 / SDA-490t
Thorens 316 / Roberts 770X (2) / ADC SS3 MKII
Polk SDA SRS / Polk SDA SRS 2.3
Polk SDA-2B (XO upgrade)
Polk Monitor 12 & Monitor 5jr.
Polk Monitor 10B
Polk Monitor 7C (XO upgrade)
Polk Monitor SW6 sub
Post Sun Oct 24, 2010 5:13 pm
Re: display lamp spec for TLM-3600?
Dennis...you can use a 12 volt car dashboard lamp...the old ones #194 was what I use. Bend the leads down and soldier into place where you removed the old bulb.
Bulb 1.jpg (8.17 KiB) Viewed 346 times
Dennis47
Post Sun Oct 24, 2010 11:46 pm
Thanks Kingman...............I'll give it a try.
Is the illumination from the 12v car dashboard
lamp about the same as the original lamp?
Polk Monitor 10B
Post Mon Oct 25, 2010 6:58 am
It will be a little brighter but was as close a fit as I could find. I think you will find it satisfactory.
Dennis47
Post Fri Nov 05, 2010 8:33 pm
I found the replacement #194 lamps at AutoZone.
I elected to use an amber version bulb rather than
the standard clear bulb. The AutoZone part number
is Sylvania #194NA (amber) Marker Light. The result
is a pale yellow orange illumination which matches
my TX-12 Tuner's VU meter perfectly. The TX-12
meter is slightly more intense than the meters on
my TFM-45 amps, but still a very good match.
The replacement of the lamp took all of 15 minutes.
Kingman..........Thanks again! :D :D :D
Polk Monitor 10B
Post Fri Nov 05, 2010 9:03 pm
Dennis47 wrote:I found the replacement #194 lamps at AutoZone.
No Problem...
