It is currently Wed May 22, 2013 8:41 pm
need VU meter bulb spec or resource for M500t
LesConnally
Post Tue Jan 27, 2004 10:14 pm
VU meter bulb spec for M500t
(is it M-500t or M-500t)
A buddy needs the VU meter replacement bulb spec for his M500t.
Or source. or both.
Thanks - its appreciated!
Post Wed Feb 25, 2004 11:59 pm
M500T Lamps
Les,
There is no Carver part# for the lamps, Only a supplier part# which is BF352-53001A and B since there are two lamps. They are 8volt lamps rated at .25 amps. Let me ask you did you try to get these from carver? I spent hour upon hour on the web trying to find these bulbs with no luck. Finally, I found a guy who had an 8 volt .175 amp bulb which has a little less intensity and bought all he had. I changed both bulbs and really didn't see much difference. hope this helps
LesConnally
Post Thu Feb 26, 2004 6:27 pm
Sorry to have let this linger. Rita at Carver took are of me completely. They werent exactly cheap @ $5, he balked, and I ended up just buying them for his birthday because no, noone else does have them. I also made my buddy sign off on the new bluish tint of them, and it turns out, he was really happy they had the blue tint.
But basically, Carver *could not have been nicer* and took care of the problem perfectly. I was surprised parts were still factory available.
And BTW, I also needed a box for a Sunfire amp, to ship it, and THEY also *could not have been nicer*!!
What a stupendous Customer Service department!
lkapphahn
Post Fri Mar 05, 2004 11:06 pm
Meter Bulbs
I also need meter bulbs for my TFM-55x and TFM-15cb. Where exactly did you get these replacement bulbs? I have had no luck finding them on line. The bulbs inside the TFM-15cb are about half the size of the ones inside the TFM-55x. Thanks foa any info on sourcing these bulbs.
epilespaul
Post Fri Mar 19, 2004 11:06 pm
VU Meter Bulbs
These Bulbs are commonly known as "A Grain Of Wheat" And can be purcheased from MAT Electronics or MCM
