It is currently Mon May 20, 2013 9:04 pm
Capacitors
Rainman
Post Wed Mar 23, 2011 3:26 am
Re: Capacitors
Don't let him fool you. His guideline is simple... If you are not sure about it then just install the fix all, they work everytime and you'll get more sleep :lol:
Rainman
Flux Capacitor..JPG (58.11 KiB) Viewed 163 times
Post Wed Mar 23, 2011 7:49 am
Re: Capacitors
Rainman wrote:Don't let him fool you. His guideline is simple... If you are not sure about it then just install the fix all, they work everytime and you'll get more sleep :lol:
Rainman
:lol: :lol: :lol: :lol: :lol:
Post Fri Apr 01, 2011 8:55 pm
Re: Capacitors
Well I have the new capacitors in, the new relay in, the new meters in.
The amp plays fine and sounds good. It still takes about five minutes for the relay to kick on. ](*,) ](*,) ](*,)
Anybody know what I should go after next ? I'm thinking some sort of rectifier something ?????????? :-k :-k :-k
Help me BillD. [-o< [-o< [-o<
Post Fri Apr 01, 2011 9:10 pm
Re: Capacitors
Sounds like a thermal problem to me. Something is preventing the relay from kicking in until it warms up sufficiently. It's probably something shorted that expands and un-shorts when warm.
Post Fri Apr 01, 2011 10:37 pm
Re: Capacitors
Got any quicky ideas of what to look at Bill ? I only have about thirty bucks into this thing so far. Maybe I should just let it be until it dies ? Maybe it'll never die ! Thanks BillD. O:)
Post Fri Apr 01, 2011 10:44 pm
Re: Capacitors
No, that kind of problem is hard to track. You might want to leave it on forever.
Post Fri Apr 01, 2011 11:00 pm
Re: Capacitors
check the solder joints on the protection side, and or, on mine. it had a bad transistor in the protect circuit, this in turn did not turn on the relay.
Post Sun Apr 10, 2011 7:11 pm
Re: Capacitors
mbskeam wrote:check the solder joints on the protection side, and or, on mine. it had a bad transistor in the protect circuit, this in turn did not turn on the relay.
Can you take a picture and show me which one or ones it was ?
I'm loving this little shit right now as I type this. New caps made a world of difference. I took Bill D's advice and turn it on in the morning and leave it on. Sure wish I could figure it out. It's not worth sending it in to fix it IMHO. It sounds great as it is. Hope it keeps going.
