It is currently Tue May 21, 2013 5:35 pm
TFM-25 Issue
Audiophile_719
Post Fri Apr 22, 2011 11:34 am
TFM-25 Issue
Hello gentlemen ! Great day to be an audiophile isn't it ?
I have just recently purchased a TFM-25 and it worked wonderfully the day I got it home and hooked it up. However, now when I power up my system and start playing it, my left channel is extremely weak. When I turn the volume up to about a quarter, it seems as though I have crossed wires or something leading into the left channel of my system, then the over load inside the amp kicks on and shuts down for a few seconds. I originally thought it was the speaker, so I switched them around and the problem followed the speaker. I then suspected that my HR-742 may be having issues. Divorced the amp and problem went away.
So I guess my question is, what could be going on inside the amp? As not being knowledgable of how to repair this or even where to look, I would greatly appreciate some advice on something to look for, or if I should send it off to be repaired.
Thanks for your time gentlemen.....
The Eye Can See What The Foot Cannot Kick
Post Fri Apr 22, 2011 12:00 pm
Re: TFM-25 Issue
If the problem followed the speaker, then the speaker is the problem.....yes?
Post Fri Apr 22, 2011 1:12 pm
Re: TFM-25 Issue
I have to agree with Rabbit...If you swapped your speakers and the problem followed your speaker then it has to be something with your speaker.
Post Fri Apr 22, 2011 1:24 pm
Re: TFM-25 Issue
Except "Divorced the amp and problem went away" would say that the amp IS the problem. I assume by this you mean that now, with a different amp, you have NO problems (with either channel)? IF this the case, (and the problem "follows the speaker" with and only with the TFM-25), then that implies that the Carver amp (and only the Carver amp) has an issue with your left speaker. That seems strange and not likely, but none the less possible (perhaps this speaker has an issue that is causing it to be very low impedance and the Carver 25 cannot handle this issue whereas your "other" amp can......we probably need more info to resolve your problem! - Ed
Audiophile_719
Post Fri Apr 22, 2011 1:37 pm
Re: TFM-25 Issue
Let me be a little more specific. On the back of my amp, I unplugged my speaker cables and switched them around. Essentially changing which speaker is being driven out of the left channel of the amp. Problem still exists, but since I switched speaker leads around, the speaker I switched into the left channel is now doing the same thing.
Like I said, once I took the Amp out of the equation, plugged my speaker cables into the back of my receiver, I do not have that problem anymore. So running my system ampless, everything is fine. I have primarily narrowed it down to being the left channel of the amp trying to take a dump on me.
I hope I explained this a little more clearly now...Thanks again gentlemen
Post Fri Apr 22, 2011 1:42 pm
Re: TFM-25 Issue
Bad left channel in amp. Take off top and look for any broken soldier joints or possible dark marks that look like burnt spots. Send amp to Rita or Rolland for repair. May be the caps.
Post Fri Apr 22, 2011 8:37 pm
Re: TFM-25 Issue
Wabbit and thuffman03 are full of beans ! :rolleyes:
Left channel in Amp is shot !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! I'll give you $50.00 for it. Site unseen. :D
Post Sat Apr 23, 2011 6:03 pm
Re: TFM-25 Issue
I can fix it. \:D/ BTW, there should be plenty of "burn" marks on the board on the TFM-25. Service bulletin fixed that issue. Had many 25's that looked like a mess but functioned proper.
Post Sat Apr 23, 2011 6:11 pm
Re: TFM-25 Issue
beemers417 wrote:I can fix it. \:D/ BTW, there should be plenty of "burn" marks on the board on the TFM-25. Service bulletin fixed that issue. Had many 25's that looked like a mess but functioned proper.
Hey man !!!!!!!!!!!!! :lol:
