silver 7t pegs meter
67ih4x4x4
Post by 67ih4x4x4 » Fri Jun 17, 2011 1:18 pm
My new 7t is doa out of the box. With no input or output hooked up the meter pegs then starts bouncing. Should I be looking for a power supply regulation problem or a output transistor shorted?
Re: silver 7t pegs meter
Post by Don » Fri Jun 17, 2011 3:57 pm
Cut and Paste from other post:
67ih4x4x4 wrote:
Very pleased with the speakers but I havn't had a lot of time to devote to placement yet. I have bought a ct-26v and a 7t and both arrived doa, so that has taken what little time i have.
That really sucks!
Don't know a thing about either one. However, I am sure someone will chime in.
I have to ask, if you just purchased these and they arrived DOA, can you send them back? Or, if you paid with Paypal, dispute and file a claim. Have you contacted the seller and what was his response?
Post by kingman » Fri Jun 17, 2011 4:39 pm
67ih4x4x4 wrote:My new 7t is doa out of the box. With no input or output hooked up the meter pegs then starts bouncing. Should I be looking for a power supply regulation problem or a output transistor shorted?
If it's the power supply I'm pretty sure you're up the creek without a paddle. Fixing is an option if not. Me...return it and wait on another PAIR that work!!!
Post by beemers417 » Fri Jun 17, 2011 8:35 pm
I can fix it. \:D/
67ih4x4x4
Post by 67ih4x4x4 » Fri Jun 17, 2011 9:31 pm
any thoughts , the seller says he checked it before shipping and it worked fine. If thats true I cant imagine something shorting out during shipping. Maybe a bad connection?
Post by TNRabbit » Fri Jun 17, 2011 9:34 pm
HRDROKN just had the same amp delivered with damage from the transformer coming loose.....have you opened it up yet?
& why only ONE amp?
Post by elgrau » Fri Jun 17, 2011 9:36 pm
Open up the hood and visually check very carefully for any shipping damage.... IF seller is telling the truth (that it worked fine before shipment), then almost has to be some kind of shipping damage...
67ih4x4x4
Post by 67ih4x4x4 » Sat Jun 18, 2011 8:01 am
The thought about shipping damage is about what I am thinking. I have opened it up and have yet to find anything obvious. I bought just the one because you have so start somewhere and I kind of wanted to see if it would be better on my AL-lll's that my m4.0t .
Post by treitz3 » Sat Jun 18, 2011 8:06 am
I would return it. I can tell you first hand that the power of these will be more than adequate to power the ALII's. The sound will be slightly different but there is no worries about it being able to power them. A DOA amplifier is just that. Nothing more than a doorstop.
The seller needs to make this right, not you. Oh, my manners. Welcome to the Carver forum.
Post by beemers417 » Sat Jun 18, 2011 12:51 pm
If something got jarred in shipping, which is a possibility, check for a loose solder joint(s) on the supply board. I have had this before. Bad, loose solder joint on a cap.
67ih4x4x4
Post by 67ih4x4x4 » Sat Jun 18, 2011 1:14 pm
Eureka its alive ! looks like the adj pots were oxidized.
Post by elgrau » Sat Jun 18, 2011 1:19 pm
Cool! Happy that it's "alive"! :lol:
Post by beemers417 » Sat Jun 18, 2011 1:31 pm
Sweet!!!
67ih4x4x4
Post by 67ih4x4x4 » Sat Jun 18, 2011 6:12 pm
Been running for about 4 hours strait, its running cooler that the m-4.0t running the other channel . I am still undecided about the sound . Definitely different than the 4.0 .
