It is currently Sun May 26, 2013 2:50 am
Bias adjustment M-1.5t
Post Sun Jun 19, 2011 7:18 pm
Re: Bias adjustment M-1.5t
\:D/ \:D/ Welcome to the forum!! \:D/ \:D/ I'm not a tech by any stretch of the imagination but I'm sure someone here can help, good luck!!
Post Sun Jun 19, 2011 7:31 pm
robert r might know as well as bill . otherwise this is a question is better suited for the other side.
Post Sun Jun 19, 2011 7:57 pm
Well, with that low a bias, you are probably getting crossover distortion (the positive/negative transistors shut off before the waveform crosses zero). What I would try is to move the adjustment trimmer a little while measuring and see if it increases (or decreases depending on where your probes are.
Post Mon Jun 20, 2011 4:46 am
Welcome
