It is currently Wed May 22, 2013 6:45 am
Loud 'Pop" on CT-6 Preamp when switching input source
Post Thu Nov 24, 2011 11:59 pm
Re: Loud 'Pop" on CT-6 Preamp when switching input source
Send it back and chew that guys ass! :x No sense it takin' in someone else's garbage and payin' 'em to do so!! [-( Lots of good working units out fairly cheap.
Post Fri Nov 25, 2011 5:59 am
I'm in total agreement. Get your money back and buy another before you DO regret it!
Post Fri Nov 25, 2011 9:09 pm
This usually would indicate that DC is present where it shouldn't be. Likely a bad blocking cap. If one's bad, then it's time for all of them to be replaced.
So with a little circuit knowledge, a volt meter and a less than a $5 cap, it might be fixed. On the other hand, whatever the going rate is for a shop to do a full run thru is the other end of the spectrum. Someone that's had that done could better put a price on that than I can, but what...probably $150-200?
PS...yes, you should be concerned about spkr damage!
